OK - Update:
Well, as things have it, I think I figured out why the ISG (Idle Stop and Go) stopped working. It so happens that a bracket on my iOttie wireless charge broke:
https://www.amazon.com/gp/product/B0754NDNT8/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
So, I disconnected it, and viola - the ISG (Idle Stop and Go) started working. It appears that the wireless (induction) charging system is a big enough drain on the system that it prevents the ISG (Idle Stop and Go) from kicking in. I did a little more experimenting. I decided just to plug my Samsung Note directly into a USB port (as I normally do so as to have Android Auto operable). The ISG (Idle Stop and Go) worked for about 45-60 seconds that went yellow - it seems just having a phone connected to the car is enough for the ISG (Idle Stop and Go) to disengage within a minute. I played around some more and confirmed that if climate control is cooling the car, the ISG (Idle Stop and Go) also does not engage (as mentioned in the owner's manual).
Needless to say, I cancelled my appointment with the dealer, until I spoke again with KIA, which I did. KIA said well, bring the car to the dealer so the dealer can replicate what I discovered. I will do that when I have a chance.
So, the question is, is this acceptable? Should the drain of a cell phone charging be enough to disengage ISG (Idle Stop and Go)? Especially since you have to have the phone plugged in to have Android Auto (or Apple CarPlay) running? I think not, and I intend to go to the dealer, have them replicate this and then pursue it with KIA. Probably all that is needed is a software tweak. I cannot imagine a charging cell phone would risk draining the car battery within a minute.
The community's thoughts on this would be most appreciated.
Thanks
