Winter Tire Package
Winter tres are 225/45/18; same size front and back.
I used a 5mm spacer in the front for the brembo clearance on my hub centric rims. Have been driving since December in these rims, no issue.
which spacers did you buy and from where?
We ordered the rims, and I warned about the clearance, but my tire dealer was very confident. After they found the error while installing, they decided to throw in the spacers.
I have a 2021 Stinger GT2 Awd and I got the winter tires and wheels included with the purchase of car, Kia dealer supplied the rims and tires mounted..
I just installed the winter rims and drove car a few times , now my check tire pressure monitoring system light is on continuously!! if dealer supplies rims and tires do they not include tpms sensors in the rim???
I would assume unless they stated in the deal they are included I can only guess they were not. Check your invoice and call the dealer.
If you did not talk about it and add it to the work order - then no. Many - probably most Kia customers simply go the cost effective route
I am having trouble visualizing a 5mm spacer that is also hub centric - does such a thing exist?
