Onno P
- May 9, 2018
What is the purpose of the BPV?
My understanding is it recirculates wasted air freshener the turbos back to the intake.
Will try to explain:
When under boost and releasing your foot from the accelerator the turbo’s are still at high RPM and you ( suddenly ) close the entry to the inlet manifold. Pressure has to go somewhere and is bled off through these valves to avoid pressure peaks in the inlet pipes between the turbo and butterfly valve.
Second advantage is that the turbo’s CAN release the pressure making it easier to maintain high RPM and being ready to spool up again when you put your foot down.
-BPV’s redirect their wasted air back into the inlet
-BOV into the atmosphere. These make the most PSSSSSSSH
-Combo-valves are available where it is a BPV when releasing the throttle partly and turns into a BOV when fully lifting your foot.
