Oryan
And I keep explaining to all you all what happened: The needle bounced well into the red zone, then immediately dropped below c. 5K RPM, and in a higher gear: I was in Manual Gate, i.e. shifting myself; yet the car took me out of manual, despite the shifter still being in manual gate. You say that over revving is impossible: I am telling you that I did it, but only for an instant. Are we talking about the same thing, just seeing it differently?
LOL! That I was, but only once.
You said that poorly: 99 out 100 of "us" do not drive performance cars. Now, if you mean 99 out of we Stinger drivers (many of whom already have sports/performance car experience), maybe you are right. But I know that @Paul32 (for one) doesn't want to shift for himself so probably doesn't care. Most people don't care for manual mode in the first place. The few of us who do shift for ourselves can use manual gate (or the Sport mode equivalent in shift by wire?); and then we don't have "D" showing up at annoying moments.
I like the nanny because I might forget again. (Senioritis) As long as I am driving the damn car and not standing it on its bloody ear I am fine; the nanny won't show up. You sound like you're advocating for the removal of a feature which can save the engine from your own mistake; just because a Ferrari does it that way.
I can assure you that you were nowhere near actually causing damage to the car. The indicated redline on the tach is lower than the ECU's rev limiter which will, at worst, bounce you off that point repeatedly and will be considerably below any mechanical design limitations of the engine itself. It won't let you break it. Nobody is making any mention of removing that. What's being discussed is the ECU actively upshifting before that point while in manual mode prior to it.
