Sales@Tork
Is the turnaround time really 3 weeks?
I put that on all the parts we make. It is there in
case we run out of materials and have issues getting more or something. We have material in stock to make more right now.
That you!if you want to see a rough idea of what they look like.
I noticed on your website that the K+N filter is a $22 upgrade. Do you think there is any advantage in choosing the upgrade, and have you done dyno pulls both ways?I put that on all the parts we make. It is there in
Tork Motorsports you guys need to get all your products posted in the Kia Stinger Store section. They have a space title Tork Motorsports in there for you just nothing added in there for you guys yet its blank.
Hi Tork Motorsports can you please post pictures and a video of that intake installed and how it sound that would be awesome if you could, a video of the actual intake and there is no tune needed right you will not get a check engine light. there is a couple videos on the kn intake and it sounds great i wonder how this one look and sounds. i want to buy please post a video....Thank you! I had no Idea!!!
Correct me if I am wrong:
Pros
- added sound
- less restrictive than the OEM fresh-air duct thus increased power.
Cons ( and thats what I would like to know more about )
- Sucking hot air from the engine bay.
Stopping at a traffic light after some ‘spirited’ driving the filters take in mainly very hot air from inside the engine bay.
In OEM setup, because of a closed circuit, airbox connected to the outside air through the channel made from front fender, the intakes still take in cool air.
The K&N Typhoon kit had its own ‘heat shield’ Still not airtight.
So pulling away when the light goes green, isn’t an open filter a disadvantage cos of the excessively hot air or is that minimal because of the intercooler doing its job?
Sales@Tork, just a question on intake mounting and filter direction. I see the filters are pointed toward the engine, but was curious if its possible to point them toward the front instead so they're aware from turbo heat and next to the OEM air inlet?if you want to see a rough idea of what they look like.
Partially correct. If you have no isolation from the turbo heat then yes at stop or in traffic you'll be sucking some hot air from the engine. However the engine bay is designed to draw hot air out the back and cool air in the front where the filters are located. So with a little heat isolation like I added to mine,Cons ( and thats what I would like to know more about )
The K&N Typhoon kit had its own ‘heat shield’ Still not airtight. So pulling away when the light goes green, isn’t an open filter a disadvantage cos of the excessively hot air or is that minimal because of the intercooler doing its job?
Its just not proven. ambient air temps and heat soak exist in every single intake scenario. might as well just put in what looks nice and focus power convos on exhaust/downpipes and tuning.Minimal gain but can also be a loss if your engine is sucking in hot air.
I dont think anyone will deny that hot air produces less power than cold air. However, I highly doubt there would be any loss in performance. The dyno proven gains from these intakes range from a conservative 4HP to a more common 9-19HP. The much larger amount of airflow and quicker throttle response would easily offset any negative from heat. Also if there are any heat effects it would only be a small factor when stopped and sitting for a while. Otherwise any heat is drawn away from the engine/intake and replaced will cool air as soon as the car moves. Worst case scenario your 4-19HP gains are slightly decreased for the first moment coming from a full stop, but then you'd have the full gains for the rest of the run.Minimal gain but can also be a loss if your engine is sucking in hot air.
