stoopid
1000 Posts Club!
Have you had your tires road force balanced? I had a car that this was needed and would create a slight shake at and above a certain speed. Road force balancing immediately resolved the problem.Bad news, vibrations are slowly returning. I notice them especially when the road surface is super new and smooth. There is a very clear vibration (fast oscillation) that cat be felt in the whole car and increases with speed. It starts as low as 65mph.
There is also a significant increase in this vibration when I apply the brakes. If I quickly lift my foot off the brake pedal the vibration stays the same in type but diminishes a lot in intensity. So I don't believe it's caused by the rotors (which are fairly new).
I also don't believe it's the tires or wheel imbalance. It's not fast enough somehow.. don't know how to explain. Plus I've been switching tires like socks, as you know if you've read the topic.
My only idea is now that it's caused by something suspension related. Either ball joints or bushings or something there.
So, a riddle:
What causes a vibration on very smooth roads but not on slightly worn roads
and
Why does vibration increases under load (linear with speed increase) and when brake pressure is applied
but sometimes it does not vibrate at all.
Discount Tire | Tires and Wheels for Sale | Online & In-Person
What is Road Force Balance? Eliminate Tire Vibrations
A road force balance test (road force balancing) detects non-balance and weight related problems associated with tire uniformity by simulating road force.
Any minor imperfection with a single tire can create vibrations (bulges, blown belt, out of round, bent rim, alignment, etc).
