The hard downshifts in sport mode
The lower the gear, the slower you should be going. The engine will hold you back if you are not at the proper speed for that particular gear...
If you are on the highway going 65 mph, you should be in 6th gear. If you must make an immediate stop, these are the proper procedures...
Brake to slow your speed. Get the RPM's down, then down shift to 5th gear, which should be around 55 mph.
You must pay attention to the rpms and speed of the vehicle before downshifting. If you shift from 5th to 1st gear without slowing down, you will ruin your engine! It'll bog down and give you that grinding noise.
Its all about getting the right gear with the right speed/rpms.
This is horse crap advice. The “puter” won’t allow you to manually downshift to a gear where that rpm would damage anything. I use engine braking like it’s going out of style.
if this was a true manual, some of your advice may be warranted (if the driver was clueless)
but even with a manual, any driver worth their salt rev matches and down shifts BEFORE slowing to a lower speed. A) to already be in the proper gear B) to engine brake. Even in some cases 6th to 4th for example.
Manuals in Europe are as common as Pizza and ever since I can remember driving one they've all had rev limiters to avoid that exact scenario. Well, unless it's a performance car with a purposely delimited system which is rare..
Mass market models are made to be fool proof, the only real way to cause damage to a modern engine is by driving it into a wall. Even then it may take several attempts dependant on velocity etc. etc. in short it's not easy nowadays to wreck an engine (from the user side at least)..
I had the same issue on my 2019 3.3liter. Transmission adaptive value reset will make it go away. As you have your transmission adaptive value reset, ask dealer to perform engine adaptive value reset as well. Hope this helps. All these resets covered by warranty.
Welcome to the forum. I still haven't had any "reflash/reset" performed; no need. I've been offered several times as I've gone in for regular maintenance.
Bumping an older thread because now at 15k miles, the downshifts (particularly 3-2) are getting extremely harsh on decel such as stopping at a red light. Comfort vs. Sport mode makes no difference. I pulled the negative terminal for a half hour, and nothing really got better. I'm more than a little annoyed this is going to require a stealership visit to reset the TCU primarily since my dealership is woefully incompetent, and I don't want to dick around with putting the stock airboxes back on.
Is anyone aware of a reasonably affordable J2534 adapter that works with Kia GIS? I have a J2534 adapter that is intended for use with Forscan, but it refuses to interface at all with KGIS even in passthru mode.
FYI an adaptives reset at my dealer fixed this issue for me. Still monitoring but it’s been about 100 miles so far and everything feels great again! I hope they release a software update for both cars to help resolve this issue but no one should hold their breath
shouldn't be an issue at all........cold air intakes are rarely if any a cause for engine failure.........why would the dealer care?
They ever say anything to me I'll say it was on there when I bought it ....now fix my car!!!!! I have a modified warranty, 100 dollar co-pay everything else is covered......recently all the work done to it was covered without the copay...go figure.
You're right, it shouldn't be. But there have been people on this forum denied warranty claims for all sorts of bullshit (including air filters), so I'm not going to give them an opportunity to screw me over.
Adding some context for people searching in the future or coming from another thread about this topic.
Pulling the battery does NOT reset the shift adaptation tables in the ECU. In many older cars, especially GM 3800/V8 PCMs, it does. It does not do it in the Stinger's ECU. This reset must be performed using KDS. I took the car to the dealer for the HECU recall and let them know that the transmission was downshifting very harshly. They performed the reset and it was great on the way home. Hopefully it'll stay that way.
Hey guys fellow G70 3.3t RWD here
Am gonna sum it up for you so you don’t have to look for answers reading the whole thread:
I had the same issue on my G70 .. very very harsh 3-2 downshifts , it got so bad that I stopped using the car
The issue is not a drive mode thing, it happens in all drive modes, and it happens when the transmission is cold or warm no real difference, the issue will only get worse over time, the issue is a software problem.
What @Snowwhite mentioned is not a real hidden reset/relearn process and doing it the way he did will change nothing.
what he described are the steps for the TCM relearn process (garage shifting) it is mentioned in the service manual but to initiate the learning process you have to use KDS or G-scan scan tool to let the TCM know what to learn and when to register inputs
The TCM learning process is not needed in our case but I’ll explain it for your information (needed when new mechanical parts are replaced)
The learning process has two steps, the first step is teach the TCM how to upshift and downshift on all gears while slowly accelerating/decelerating and this has to be monitored through a scan tool and you have to follow the instructions on the scan tool while doing that and press ok after each performed run (5 runs in total .. accelerate through all gears then decelerate through all gears)
After that you have to do the second step (garage shift learning). In this step you have to go through D for several seconds then N for several seconds the R then N then D and so on.
But as mentioned this is not needed in this case and it will not work without a scan tool as the TCM will register nothing of what you’re trying to teach it.
having it working for @Snowwhite is just a placebo IMO ... and also all he’ve done is the garage shift learning steps not the drive shifting anyway.
I got the issue completely fixed (for now at least)
The fix is to reset the A/T adaptive values (the only thing in the TCM that can be reset anyway)
I brought the car to the dealer multiple times telling them to try and reset the adaptive values for the TCM and they claim that they’ve done that .. but I saw no change in the downshifts (most probably they didn’t reset anything)
to reset the TCM adaptive values for this car you need one of two scan tools (either the official GDS/KDS or G scan) any other scan tools will show “faliure” while performing a reset
Although the other scan tools (like Launch) can reset the TCM for the G80, but not the G70 for some reason.
It’s very easy and anyone with a scan tool can do it himself
Just search for a “G scan” scan tool nearby at any mechanic shop
-Connect the scan tool to the OBDll port
-choose Kia Stinger from the menu or let it auto detect through VIN reading
-choose TCM/TCU/Transmission module
-press on reset adaptive values
done ✔️
The car will shift normal after that and will be very smooth
(there’s no adaptive learning for this platform in the G-scan scan tool as you may see on different scan tools like “launch”) somebody mentioned this before on this thread .. it’s not possible on this transmission, they can just reset the adaptives.
the question here is:
what to do/not to do while the TCM is now automatically adapting and learning after the reset? ( I just drove normal and smooth for the first 200 km without and hard accelerations)
What is causing the TCM to learn this bad downshifting?
Why isn’t the TCM automatically adapting again if it has learned this bad downshifting over time?
Genesis needs to release an update for this TCM to make it not learn this bad downshifting or make it’s adaptation better or make it automatically relearn every couple thousand miles.
this issue turned out to be more common than you might think (kia/hyundai/genesis)
and it might come back again after a while as it might learn this harsh downshifting again for some reason
I have complained to Genesis about it and sent them 10 VIN numbers of affected cars and told them how to fix the issue (reset) .. now they’ve called those 10 car owners and scheduled appointments for them and they have pulled data out of their TCU to try and figure out what’s happening with TCU and possibly release an update to fix that. After that they have reset those TSU to solve the problem.
it’s important to let KIA pull data out of you TCU before resetting so they can figure a permanent fix for this. But for that they need a special device which they will send to the dealer to pull the data from the TCU .. so someone should contact KIA corporate before visiting the dealer to make it quick.
it’s also important to reset the adaptive values of the transmission control module after changing the transmission fluid (when the time comes for that)
happy resetting:)
Enjoy your cars again
While the shifting procudure did reduce the force of the downshifts somewhat, the problem didn't disappear completely until I went to the dealer recently and had them do the reset. It's the only thing out of 4 requests I had that they did correctly. They even overfilled the oil.
they over filled mine as well......retards
Found a cost effective solution...
Viewed the genesis g70 forum too as they had a similar thread which was helpful for me to getting to my solution ... so thought I would chime in here to assist other future readers.
My ride did this behaviour also (i.e. harsher and noticeable downshift, mostly from 3>2 when coasting to or soft breaking to slow or stop, particularly when cold). I reported this at 38000km, dealer performed the reset = all ok ... until about 42500km, another visit but dealer denied me this time (wanted to do a auto trans fluid change ... wtf!) so I asked them "nicely" to just do the reset again = all good again .... smooth shifts all round, like it should be.
So I then found myself looking for a cost effective method to do this "reset" myself. I had a couple of very basic OBD2 readers/resetters already so knew a little bit about these devices. But did a bit more digging, came across this thread and found the g thread discussing a few potential devices. Then I found this little device here --- THINKDIAG --- which has the feature enabled for adaptive transmission values reset for our Kia Stinger (as described a few comments above). They (i.e. mythinkcar support) actually recommended me their dearer Thinkdiag 2 (which is a newer version) but I had found a Thinkdiag (older version 1) quite cheap avail on ebay and it works .... at cost less the $100 too !!! It may be the most inexpensive device that has this feature enabled for our cars.
Link
Thinkcar Thinkdiag OBD2 Scanner Bluetooth OE Level Diagnostic Tools
Anyway this hell annoying kia/hyundai/genesis transmission "feature" they gave us is a software bug and I can't fathom why they have not figured to resolve it at their end and push an update. But there is a way you can do this reset yourself and it may save some time and frustrations to just get on with some "smoother" driving.
Hope this helps some of you. All the best.
Hey guys kind of a Kia newb here. Recently got a GT 3.3TT awd, coming from the Audi/vw world.
In my last Audi (2011 a4) the gear box was the ZF8 (8 speed auto tip tronic) same gear box in the hellcat (hellcats get a model that can handle more torque) and now is the gear bmw is using instead of their zf8
Im hoping this is the gear box in my stinger if anyone knows please lmk.
I remember with the a4 in the forums some members talked about a rough downshift. The dealer would flash the tcu a different map version. There was several map options from the dealer iirc.
Same thing would go for an aftermarket tcu, they are changing the map/programming which will effect the shift feeling/speed
So I would not be surprised if Kia dealers had another map they can flash in 15-20 minutes.
In the vw/Audi world if you reset the adaptations and drove normally it would generally feel smoother but slower in manual mode with paddles. If drove aggressively after the reset it would feel firmer and be very slightly quicker, wonder if same applies to this platform
Im hoping this is a ZF8 it even has the torque vectoring diff like the b8/8.5 s4
No it is not ZF but a Kia-Hyundai transmission. Sometimes I wish.
Whatever the adaptive learning programming is, it is evidently not very good (... sometimes?) ... as it can adopt a bad shift pattern (for me, when cold, downshifts, mostly 3>2). Resetting adaptive transmission values reverts it back to normal behaviour. I think the transmission itself is very good and not sure why it's TCU software is buggy with this.
Has anybody used the ThinkCar tool mentioned above? I would like to know if there was a success or any issues with it before buying one.
I cant attest to the Thinkcar one but I have the Xtool Anyscan A30M and its amazing...lifetime firmware and software updates as well.
I think they are fairly similar.
I will look into that one. Thank you
