Says some who obviously and literally has never been to a track and racedThis entire thread confuses me as to its purpose. Remove parts of the car that weigh a pound or two? Seriously? What’s next? Wait, I know........
1. We should all go on diets to lose 5-10 pounds (some of us more maybe). But if you lose 1-2 pounds, that’s great also. Or just be sure to purge bodily contents before driving every time.
2. Remove the spare tire and all its trinkets. Better to be stranded and call roadside assistance!
3. If you don’t have kids or never have passengers, remove the rear seats!
4. Add every possible aerodynamic enhancement to cut down on wind resistance. Oh wait, that might ADD weight.
5. No floor mats. There’s gotta be at least a pound or two there!
6. Trade in for a RWD to save a few hundred pounds unless you absolutely positively live where it snows, a lot.
7. Drive naked. Clothing is strictly optional!
8. Never have more than 1/4 tank of gas. Those extra 10-12 gallons weigh a ton!
9. Drain all washer fluid. Heck, if you live where it doesn’t rain but once or twice a year, ditch the wipers!
10. This space left open for other inane additions to the list.
Wheels are worth far more than their static weight. Because most of that additional weight in in the barrel (or perimeter) of the wheel, it contribute a great deal to the rotational inertia of the wheel/tire assembly. If you calculate the amount of energy required to accelerate and decelerate the additional rotation inertia, it is about twice that of the same weight but static in the chassis. So the weight you are saving with those Enkei's are worth at least twice. So instead of 68.8 lbs, it'll be more like 138 lbs.Easy weight savings (Kia put unreasonably heavy wheels on this car)
After reading about people having issues with the stock brake pads, I decided to preemptively put in some z23 pads with under 300 miles on the car. I took this opportunity to weigh the passenger side rear wheel tire combo (61.4 LBS) and the drivers side front (58.6 LBS). This seemed kind of heavy so it got me thinking. The Michelin primacy tour A/S tires are not my favorite, in fact I feel they hamstring the AWD car compared to the 4S I have on my other 2 cars and offered on the Stringer in RWD.
The Stinger is my winter car, however I have a dedicated set of snow wheels and tires) so I can get away with a more aggressive tire for spring – fall.
I took a look at an “affordable” wheel tire package. I decided to go to 18” wheels for a little more sidewall, however similar weight loss can be achieved with 19’s.
I looked at the tried-and-true Einkei RPF1 in 18x9 with a 35mm offset weight: 17.3 LBS and in 18x8.5 with a 30mm offset weight: 18.3 LB (yes according to tire rack the narrower fronts are 1 lbs more).
Looking at a set of 4S tires that should work with the AWD system I went with 235/45/18, 23LBS and 265/40/18, 27 LBS
Weight savings: one rear wheel tire combo (17.3+27) =44.3 LBS
Stock combo: 61.4 LBS
Rear corner weight savings: 61.4-44.3 = 17.1LBS
One front wheel tire combo 18.3+23=41.3
Stock combo: 58.6 LBS
Front corner weight savings: 58.6-41.3=17.3
Total weight savings: 17.1+17.1+17.3+17.3=68.8LBS!
I think I will be ordering this soon
I am sorry for taking up so much room with the numbers but I didn’t believe just how much weight can be shaved!
Light ALWAYS makes right.
Easiest way to think of it is by the fact that reducing substantial weight from one end of the vehicle effectively increases the spring/damping rates on that end. This is because the coil springs, anti-roll bars, and dampers all now have an easier job at controlling wheel articulation as well as body mass movement.How would removing 200lbs from the rear of the stinger (trunk covers/liners, tools, donut, seats, lipo battery) effect track-day dynamics?
I'm afraid that was probably me a while back. To be quite honest, this is why I hesitate to answer when folks ask what I have my suspension is set to. Things like this gets taken literally and subsequently requoted without originally context. That can be rather dangerous. Suspension tuning is a balancing act. What works well in one setup might not be appropriate in another. FWIW, here's the original context: that was when I was still on Eibach springs. Since the stock dampers were non-adjustable, as were the spring rates and ride height, anti-roll bar was the only means, with which I can influence the cornering attitude of my car at the time (other than tire pressure). Now that I am on Riaction coilovers, I have set my anti-roll bars back to even both front and rear.Setting my rear sway bar to hard (front stays on soft) is on my list of track day to-dos, though I forget why or where that was suggested.
They can build it, if you can get the measurements.i want to weigh my car. i’ve done lightweight wheels, water pump pulley, brake rotors, and battery.
i wish DSS would make a carbon or aluminum driveshaft for our cars!
Really? I thought the weight differences were almost entirely in sunroof and AWD components. What else? I never did find a weight difference between sunroof and steel roof though. Guesses, but no hard number. As I recall, the added AWD is another almost 200 lbs.My GT AWD is 350 -400 lbs lighter than stock by now. Also you have to remember that gt2 is heavier than gt1. And gt1 is heavier than gt.
Sure. Wheels-40, brake rotors-15, spare with all tools and shelf-50, reat seat-50, battery-40, rear door panels and speakers-20, front seats-90, both subwoofers-10, carbon hood with front crash bar-30, all those noise dampeners with a lot of aluminium and titanium bolts gotta be at least-30lbs. Probably missing some other small parts. But you get an idea.I'd love to see the list of weight reduction mods you've made. I'm looking for ideas myself.
the difference probably is not that big. But sunroof would add around 40lbs. I know the front seats are 20lbs heavier than gt ones. 19 inch wheels will add another 10-15 lbs vs 18 inch on gt model. Electronic steering column and rear lift gate mechanism gotta be heavier than manual one. Just the stuff that comes to my head. But I wouldn't be surprised if gt2 is ~100lbs heavier than gt.Really? I thought the weight differences were almost entirely in sunroof and AWD components. What else? I never did find a weight difference between sunroof and steel roof though. Guesses, but no hard number. As I recall, the added AWD is another almost 200 lbs.
Dang! That is hardcore.Sure. Wheels-40, brake rotors-15, spare with all tools and shelf-50, reat seat-50, battery-40, rear door panels and speakers-20, front seats-90, both subwoofers-10, carbon hood with front crash bar-30, all those noise dampeners with a lot of aluminium and titanium bolts gotta be at least-30lbs. Probably missing some other small parts. But you get an idea.
Rear seat belts. Aluminum brace bars instead of steel stock ones. Secondary downpipes. Now, that's hardcoreDang! That is hardcore.![]()
Suspension tuning chartView attachment 86020
