Okay, I got my 500 mile oil change, and put the car through more testing...some of which is specific to this thread. If "manual" shifting is important, that effectively rules out the GT2. What I found was that, in any other mode than "sport" if you use the paddles to shift, it will ignore your commands as "an accidental touching" once it goes over around 600RPM faster than the computer would have chosen. For example, let's say you're in "comfort" mode, cruising at 1,900 RPM, and you downshift with a paddle, and you're RPM goes up to 2,400, and you give it a bit of gas, then it hits 2,500. At that point, the computer switches it back to full auto. If you set it to "sport" mode, it will not do that. Or, if you use "custom" as I do, the same behavior is replicated depending on which transmission setting you choose. So, if you want to drive in "comfort" mode, or a "custom" setting with the transmission set to anything but "sport", you will not be able to use the paddles for a "manual" like experience...UNLESS...you flip your T shifter into manual mode.
With the T shifter in manual, it doesn't matter what driving mode you're in, or what config you choose, it stays in "manual". Hallelujah! As someone whose driven autos only, I was surprised at just how pleasurable it was to use the "manual" mode. I will be doing a lot of my driving in manual now, it's just really enjoyable. What I do is flick the T shifter into "manual" mode, and then use the paddles to shift. It has a nice "formula 1" type feel. From tonight's driving, I also learned why some companies don't put the paddles on the wheel, but instead in a stationary position behind it. When you're making a turn that requires significant rotation of the wheel, those paddles also flip around with the wheel, and to shift up and down, they become reverse. Of course, with the T shifter, that doesn't matter, because in such situations (like making a tight left hand turn at a stop light), you can push up/down on the T shifter, and then use the paddles elsewhere (or just always use the T shifter if you prefer). The paddle shifters were quite fast, and it was a very enjoyable experience. So, for those who care about having that level of control/fun with the car, then the GT, GT1 (or the I4's if that's your thing), would be worth serious consideration. As always, test drive.
