Hi everyone,
I install the second gen tailllights on my stinger and now you don't need the famous resistor with it. They come with it, it's a 4 wire instead of 3 wire see photo but the hardest part for the installation is to separate your original paint x2 cover from the original part.
The flasher are sequence. What I did, I cut the 2 pins (guide pins) that are useless on the main center bar so it leaves you to drill only 3 holds on each side. If your going for it my best advice it's to take your time specially to remove your original cover, I'm not sure if you could order the 2 end led lights with your stinger color that would save you lots of time.
