Volvowith18psi
- May 4, 2018
I'm sure @Tork will chime in soon
Did you just pull the pipes off and break them up with crowbar/screwdriver & a hammer?I gutted my secondary cats and no codes, over-boost or issues.
Are you guys planning to do a video on primary cat uninstall? I loved your spark plug install video!We have been busy in the shop the past month and we are trying to plug away at the Stinger as we can. Here is a mock up of our Primary cat deletes. We will be installing these along with our downpipes when they are finished to get some dyno and sound results.
How many cats does the stinger have and I don't mean the fury kind?
Resonators will usually help with the RASP you are experiencing, you should try just putting those back on first.
I want to get cat deletes but noticed I will have trouble accessing the bolts on the stock cats.We have been busy in the shop the past month and we are trying to plug away at the Stinger as we can. Here is a mock up of our Primary cat deletes. We will be installing these along with our downpipes when they are finished to get some dyno and sound results.
