A Member Who Left
- Jan 30, 2018
Silky silver 11/17 with no real issues. Would you like to know numbers for folks from the Oct-Dec period with zero issues?
Also one thing take into consideration, since I've seen it mentioned on videos and posts here. The paint chip on the edge of the hood near the drivers side wiper arm (on LHD vehicles), does not count, no matter your color, as that is just caused due to improper servicing.
@forzanerazzurri "No useful data"? You speak in extremes. The data could be more useful done another way. But this poll is already producing useful data.
I'm curious as to how you figure that was improper servicing? Did you have the chips there? I had two chips that i thought were cause by improper servicing, then i tried to replicate what would have caused it. The wiper arm came no where near the chips, hood open or closed.
No, I do not have a paint chip issue there because I have made sure to put the wipers on service mode every time I am going to clean the area or check the wipers.
The wiper arm does touch at the edge of the hood if you try to lift it without setting them in the service position.
I’m trying to get a pattern to show up I can’t design a easy poll if you throw in too many variables. As you would see there is a pattern emerging now. If you can do better then go ahead and make a poll to your specs.You should have done a yes/no for each month and then calculated the percentages of occurrence. Your poll as it is provides no useful data as there isnt an even distribution of owners from each month.
NoDon't we also need a "No Paint chips vs Build date" Poll to compare to this poll ?
