windz
installed jb4
Map 1
91 octane
densos .022
P061B code - no issues prior to install
Test drive 10min ran good first day. Next day long drive about 30 min code came up car limp mode again. deleted code, ran normally, bout 30min in again code came back and car was in limp mode again.
Ive attached a log of my drive (you can see the point it switched to map 0. i also manually switched). So i double checked all the wiring. i DID NOTICE the driver side fuel wire positap was slightly loose (Positapped to fuel adapters not factory wiring). They were definitely tight when i first installed. (maybe came loose from heat)
My question is, is it possible for this wire being slightly loose cause this code and stall/limp mode?
Any help is much appreciated
Thank you
Map 1
91 octane
densos .022
Thank you
