MrSmoofy
Yes and the BMS Tial BOV adapter you can see this as it combines both into one.Ooooh, that's why we have 2 BPV's.
Pipe looks fine (stock isn't a restriction so don't expect any power over the stock pipe, we tested it), but skip the knock off Tial! They are problem prone. Get a real Tial valve for it.
On FB the guy did offer to sell it without their BOV so that is possible and they will custom paint them as wellSo maybe try and purchase this minus the knock off? Which Tial valve do you recommend?
Awesome! Do either one of you guys know which Tial valve is recommended?
I don't have an official answer on that for you as it's way at the bottom of my list of things to do so I've not researched it but Sal on his site has Tial BLACK (6psi) but he sells it with an adapter which you wouldn't need. Most other Kia parts stores are selling them in pairs. Also looks like BMS recommends the same and sells their adapter with the Tial BLACK as well. Based on just that I would say that's the recommended as BMS has probably done a lot of testing with it for their adapter. There might be a different recommendation though since this it's a bit different then just being an adapter.
They come in different colors, they just happen to use a black Tial.
What they are using is a Tial Q 50mm BOV with a 6psi spring, you can get it in black,silver,red,blue,purple.
There ARE other companies that have 50mm BOV's but you'd need to make sure they work with a Tial V-band clamp/flange.
Actually they said on their FB post that it's not a Tial it's a Tial knock off
