I have a RWD and traction even at the drag strip is an issue with the stock tires and having mods. I just went to 18" wheels and will be using some 285 drag radials this coming spring. Unfortunately it's too cold here now for the drag strip so I'll have to wait until the spring to see how much the new wheels and tires work.
WMI starting to show some promise. Temps in the mid 40s and car could have been lighter but hit a new stock turbo record valid 121.65 MPH trap and a just invalid 122.78.
Also hit a record trap in the 1/8th 96.25 MPH
terry i have been tearing through forums trying to locate the info myself and cant find it. is there a video or a set of instruction on where/how to install the spoofing wire? and for someone like myself who isn't super knowledgeable about electrical what gauge wire would be used and is there a specific type resistor you would recommend for making this wire? and as far as the values to enter under 6cyl timing is there any chart that explains what the iat is and what values need to be entered to get the spoof to add more boost?
@xot1 - do you know if Lee Taeho has brake snip? Doesn't look like it but hard to tell with big turbos.
He had -2500 to my -1500 DA for my 11.51, I will avenge!
