Hey Guys,
Sorry for the delay, just a slight hiccup that delayed the post by a few days, but here we go! As always, make sure that you head over to the
Engineering Blog for the full writeup on our testing, including a plethora of graphs from our testing!
Cooling power is key for the intercooling system, especially once the boost gets turned up. I can only assume that’s why you’re here, so we strapped our Stinger up to our DynaPacks for a torture test in the name of science. Our testing consisted of two stages in order to get a good look at just how well our intercooler kit performs against the stock unit.
First up, we have our power pulls. In this test we performed a single power pull on our dyno in order to get a focused snapshot on the difference between the two kits. For this first round, the vehicle was brought to operating temperature (185°F) by idling on the dyno, and a single pull was performed, with a short breather in between tests to ensure a consistent starting temperature. With the shop’s ambient temperature of 70°F recorded, it was time to start the tests. Here's a quick comparison on just the outlet temperatures between the stock unit and our kit on just the power pulls:
Since I’m sure many of you don’t live your lives a quarter mile at a time, we also devised a test that would simulate daily driving, but under the harshest conditions. For our heat soak test, we started out with the same warm up procedure, with the same measurement of the shop’s ambient temperature, however, instead of giving the Stinger a break between runs, we ran 6 consecutive pulls. We also ran all of our tests twice, once with stock tuning and again with a stage 1 map to ensure that we were actually providing a solid base for the addition of more boost and heat. Here's a comparison of the outlet temperatures on the stage 1 map during our heat soak test:
The improved foundation is the main goal, but the increase in flow and vastly improved cooling power are the two main ingredients when it comes to cramming a few more horses under the hood. To see just how much power did ended up adding on both the stock tune and our stage 1 map, make sure to head to the
Engineering Blog! As always feel free to shoot over any questions you might have!
Thanks,
Nick
