Just to clarify. It’s 25lbs lighter, is that just the MRBP cat-back compared to stock? Or is that downpipes as well? I’m asking as The system doesn’t necessarily look a whole lot lighter than the stock, but I have no ideas I haven’t weighed them side-by-side.I exaggerated on the weight. The stock exhaust with 2" piping weighs a touch over 40 pounds. The MBRP system with 2.5" piping is ~25 pounds or so. Still about a 15 pound difference!
That’s just the catback exhaust comparison. Its 15 lbs lighter then stock.Just to clarify. It’s 25lbs lighter, is that just the MRBP cat-back compared to stock? Or is that downpipes as well? I’m asking as The system doesn’t necessarily look a whole lot lighter than the stock, but I have no ideas I haven’t weighed them side-by-side.
Thanks! I just didn’t want to buy an exhaust system that was heavier.That’s just the catback exhaust comparison. Its 15 lbs lighter then stock.
Midpipes don’t come with the MBRP exhaust so not included in this weight comparison.
NothingThanks! I just didn’t want to buy an exhaust system that was heavier.
How much gain from just the cat back in the 1/4 mile?
No performance gain? I gotta ask, what’s the point? Just the better sound? They are dyno charts with whp gains, I would think possibly a tenth.Nothing
It will depend on your laws in your state. In CA, where I live, you have a substantial amount of time to be able to mod your new car before having to worry about state inspections.If replacing the secondary down pipe with catless does not throw a cel, would it be safe to say that a state inspection would not be an issue?
Yes correct. Also the MBRP’s will open up after awhile and sound much better.I installed the MBRP cat back on my sons 2020 GT1 this weekend and it sounds nothing like this. He was wanting something with a similar sound so we ended up pulling off the mufflers and running straight pipes to the tips.
I read above that removing the second catalytic converters doesn’t cause check engine lights or a programmer. Is that correct? If so we may try that and put the mufflers back on.
Hello Mr Smoofy , exhaust sounds great. Did you replace the entire exhaust or just sections.Here is what my ARK secondary downpipes sound like couldn't do much reving because I live in an apartment building and my garage is next to an apartment, must suck for them.
Wondering how MBRP will sound with this, yours sounds pretty fantastic to me.
Also, I'm not sure why there is a squeak when I press the throttle might need to get that checked.
I have the SSR pipes. They were the only option when I bought them. They should all sound the same and as long as the fitment is good on the DC’s I’d go with them and save some money.I was wondering if anyone has the MBRP exhaust paired with DC Sports secondary DP's? I originally was looking at ARK Performance & Jun BL for secondaries, but I can get the DC Sports for $150 - $200 cheaper. Design-wise, all 3 look identical as it is such a short run of exhaust piping, so it's hard to imagine the sound would be any different than the OP's video of the purple stinger with MBRP + JunBL secondaries. I love the sound throughout the entire rev range as it sounds clean & deep with no rasp.
The only difference is likely weld quality. I have the MBRP/ARK combo with aftermarket Tips no complaints other than one of my cheap tips rattles on start up.I was wondering if anyone has the MBRP exhaust paired with DC Sports secondary DP's? I originally was looking at ARK Performance & Jun BL for secondaries, but I can get the DC Sports for $150 - $200 cheaper. Design-wise, all 3 look identical as it is such a short run of exhaust piping, so it's hard to imagine the sound would be any different than the OP's video of the purple stinger with MBRP + JunBL secondaries. I love the sound throughout the entire rev range as it sounds clean & deep with no rasp.
I believe the DC secondaries are rwd only btw.
. I was so excited to get these downpipe for only $276 through Amazon or Walmart (lol....yes even Walmart has them available for shipment). Looks like I'll have to save a while longer for the $600 Ark or $650 Jun BL DP's.
