I also just have my car diff oil changed from the dealer and it has the same noise. Did you ever get it resolved?
Nope still not resolved. I think Im on #3 or 4.. not sure, and not much point at looking at the paperwork as either # is too much.
LSD#2/3 included the transfer case replacement and had to get new staggered tires, else no warranty. I am still not happy about that.
LSD#3/4 will be new and with now with equivalent 3rd party oil. Presently trying to figure out a oil that will work WITHOUT adding additional FM, but everything I have found has been all over the map and is not 100%.
The dealer been good through all this, but I hate that they are the only pressure point to get this resolved. Kia Canada is pretty much useless.
Presently have this for info (because no-one seems to follow up, and may help someone else);
3/4x LSDs that have had 300-1000+ km for grinding to become noticeable (becomes more audible as the km accumulate). ~1200 -1500 km will be audible @ ~20km+ in stop light 90° turns, with HVAC/Audio going (reasonable levels). Standard driving, no burnouts, drifts, racing etc.
What I have found so far, for compatible lubricants;
***Doesnt Work***
Mobil 75w-90 LSD  - does not correct grinding/whining sounds
Valvoline 75w90 LSD - does not correct grinding/whining sounds
OEM 75W85 LSD GL5 - does not correct grinding/whining sounds
***Works***
Redline GL-5 75w90 - seems to work as is
Amsoil sever gear 75w90 - seems to work as is. Some add F.M. on top
Royal purple 75W90 LSD - seems to work as is
Lucas Synth 75w-90 - seems to work as is
Valvoline 75w90 LSD + Trans-X Posi-Trac LSD additive - Seems to work
***Additives***
Mopar LSD lubricant
CRC Trans-x
Amsoil Slip Lock
This list isnt 100% and is based off Stinger/
G70 forum comments and have minimal to no followup confirmations. So.. take it with a grain of salt. Let me know if you have had experience and any data to back it up (Lubricant info, FM info (if added) and km/miles when done, km/miles since install, and any issues noted since)
