mldavis2
1000 Posts Club!
I think you need to distinguish between a true racing engine, and a street driver. The idea of variable speeds it to assure that mated surfaces polish together at ALL the various operating speeds at which the engine is likely to be used over the life of the vehicle. A racing engine (the hemi for example) is intended by racers as a WOT engine, so breaking it in at the RPM at which it will be used is desirable. It also doesn't have to last 100,000 miles, either. Your Stinger will likely be run from idle to 6,500RPM. It needs to be "seated" in at all operating RPM's which is why the factory advises variable break-in speeds.
