Finally completed my exhaust journey today! Got the 4.5 inch tips put on to fill the gap better. 5 inches was going to rub most likely and i didnt want it to cause issue.
I also got the wireless valve controller installed. I took a short video:
Here is the valve controller on amazon:
APR MS100170 Exhaust Valve Remote
It will work with the mbrp pro as well. Really handy when you want control. I didnt want the valve to close on cold starts. I like to annoy my neighbors! It plugs into your existing wiring, super simple. The kit comes with another blank connector so you can seal off the other factory valve connection to not get damaged. The active valve system in stock only opens partially when you are using throttle and fully when you are gunning it. Well i wanted to be able to control it so it stays fully open.
Anyways hope this might interest someone. Of course this for 2022+ stingers only.
