Drag/Acceleration Kia Stinger 1/4 Mile Times
Status
Not open for further replies.
Reduced boost in 1st gear to help with the launch, went a bit quicker. Most of the gain probably from the extra slope. For a 1WD vehicle it's just difficult to put the power down out of the hole. Even with better tires.
Am I seeing much less throttle cut and timing pull on the shifts? Looks like it isn’t pulling as much then. SOLID TIME.
I like the progress.
View attachment 15957 View attachment 15958
Agree, less throttle pull and much less timing pull on shifts. This is where Terry and John hug and we all benefit in advancing the platform. :) I'm guessing we are going to see the third 11 second Stinger sometime today.
No hugs!!!
This is evidence of how heated competition can help us all.
I say they stay at each other's throats so the rest of us can go faster! :rofl:
How about Kisses?
.08 of this is in wheel weight reduction but thats a valid mod like all others.
My 22 lb 19 inch Momo RF-5Cs are being built now. I needed the 19s to keep rolling in style.
How about Kisses?
.8 of this is in wheel weight reduction but thats a valid mod like all others.
You mean .18? He ran a 12.18 before the wheels.
.8 reduction would mean he was running 12.8x before new wheels. Or am I reading you wrong?
Saying .08 was the wheels the rest was tires and tune. Rotational wheel weight should be about 1.6x actual weight so 50 lbs x 1.6 equal to an 80 lb reduction or .08 seconds.
Edit decimal point correction
Sayng .8 was the wheels the rest was tires and tune. Rotational wheel weight should be about 1.6x actual weight so 50 lbs x 1.6 equal to an 80 lb reduction or .8 seconds.
Your math is hilariously flawed. Maybe 0.08 seconds.
I'm still lost.
Are you saying every 100lbs dropped is 1 second off the 1/4 mile? :thumbdown:
Yes .08 obviously, typo.
Lol ok good. I'm debating on which lighter weight wheels to get myself. How wide are you going with the Momo's?
I’ve only had two Martoonis, I’m not as think as you drunk I am. :rofl:
8.5 and 9.5 with stock tires.
And if i can start spinning those i got room to go a little wider.
Stock 19" rims are a tragedy! The 18" Enkei rims rims are a touch under 19# each, I did 9.5" in the rear and 8.5" in the front. Saved 52# all around on the bathroom scale. Seemed to be worth around 1mph, ET is harder to tell as there are a lot of factors. Maybe nothing maybe .1ths. Tonkabob will be a better case study for that as he doesn't have the traction variable. I wonder what the factory 18s weigh.
My car is open diff still, FYI.
Oh I thought you were a GT2. Hurry up and get back to the track to up the ante. It's going to get boring if I pass you. :)
Status
