Did you put straight pipe in place of muffler? If not how is the soundwhat plugs do you recommend? also how many catch cans needed for the 2018 stinger gt2? last for now open or closed k&n air intake? i deleted the mufflers am i missing something?
No straight pipes. it’s a very deep growing soundDid you put straight pipe in place of muffler? If not how is the sound
@Terry@BMS Have you seen any changes in MPG with the fuel control?
what are you doing Kamauxx?Okay so I just installed the wires. I uploaded V3 Firmware last week and it already had the values for fuel bias.
Is there any additional steps I need to take? Do I have to hit an "activate" button or something? Or should it be good from here?
blue wire to the red wire on the JB4 to power it. use the tap provided and make sure pointed side is on correctly. also make sure you do it outside the JB4 boxWhere does the blue wire go that's comming off the bluetooth connect module?
