Angel
1000 Posts Club!
Does it only activate when you run map 8?That’s what I love about the system from BMS. Since it’s oaired with the jb4, I only need to run it when I choose to.
Yes. Although, I can change some setting to have it run one other maps. But, I’m not interested in doing that until I create a map6 for my own enjoyment. LolDoes it only activate when you run map 8?
That trunk tray is very different than US cars.It takes absolutely no space in my car.View attachment 21674 View attachment 21675
Yes, unless you live on the North Pole or Antarctica then there can be an argument made.Is there any real benefit in upgrading the intercooler if you live in a cold climate?
Based on the fact you've got a US flag under your name.. Unless you're in Alaska there's a benefit to upgrading the intercooler.
I'm in Alaska lol
Is there any good data on actual gains with FMICs with stingers? Im kind of under the impression there isn't a ton to be gained upgrading the factory one unless you're getting into squeezing out that last 5-10hp or you have every other mod already and are just running out of ways to make gains. Going too big can introduce lag and slow velocity too which can rob low end power too. Do we have any back to back Dyno charts with a Johnny Tig or similar?
Power gains are going to be much bigger with the WMI from what I have seen on other vehicles builds IMO. The temp drop is huge and instantaneous. If you're chasing max gains, I think this is the way to go over a FMIC.
It was a close poll.
Intercooler got the most votes.
I guess I will be buying an intercooler.
Didn’t you already have the AP intercooler?It was a close poll.
You already spend a shitload of your time on your car, what's refilling a tank going to hurt.
Your car + WMI would SMOKE your car + intercooler in every situation.
