jerryyas5
- Dec 17, 2020
I watch the videos on the driff mode. it was a video on YouTube with the orange stinger. i did the trac And stability control disable feature, but all four tires still hold the ground,Someone needs to be trained on the advantage of D-AWD. The whole point of having it is to be able to circumnavigate “the fuse pull” to get 100% to the rears with the LSD (Limited Slip Differential) that comes on the GTS/INDIGO. It puts the power down more efficiently..don’t use launch control, brake boost but make sure everything is turned off..
but what the hell do I know, my cars orange..
I installed a switch for the fuse so I can switch it back-and-forth between awd and rwd.
