Metalmania82
Hoping someone here with knowledge and experience can take a look at these pictures and see if there's anything out of the ordinary.
Backstory: I installed the JB4 and recommended Denso plugs (gapped) @ 600 miles, I'm at 71xx now. JT intakes, 93 octane from Sunoco, rear cat delete, oil changed every year before winter storage. Haven't had any issues until this spring when I started driving again. After a cold start, under mild/normal acceleration, mostly in third and fourth gears in both "manual" and automatic, the car seems to hiccup and cut throttle for a split second. After a couple miles and she's warmed up, drives fine, no issues. Been like this for several months now, no CEL or pending codes. Decided I would pull the plugs and see if there was any kind of corrosion or carbon buildup that might be causing this issue (also going to recheck the gap later today). Plugs seem fine to me, there's no oil on them. I used my bore-scope and took some pictures but I have no real experience with this.
Any insight will be greatly appreciated!
