Angel
1000 Posts Club!
For sure, but considering you can pick up a usb borescope/endoscope for like $10, if there was a simple 10mm bolt to pull out, and you could take a look down at few of your valves, I'd be more than willing to go down that route instead of just doing a CRC treatment every 10-15k
I am sure you can buy one of those inspections endoscope cheap online. Not sure If there is an easy way like a bolt. The only way I can think of is to remove the spark plugs and look thru there, which is time consuming and not easy for everyone to do. You could also look thru the throttle body which would be the easier route but not sure if the endoscope is long enough.
