I’m having the same Issue, it is still winter for me. I found that my rear vents were closed, while blasting heat. Also, a lot of the heat seems to be coming from the wireless charger. After messing around, I found that turning off the wireless charging pad and making sure your rear vents are open significantly reduces the temperature of the center console. However, mine tends to still get a little warm when I’m punching it constantly or going on a long drive, especially in sport mode. I am not stock though so I don’t know if stock stingers will have better results from this. BTW wireless charging pad can be turned off from the dash settings using your steering wheel.
