Thrashmetl
- Feb 26, 2018
Title says it all.
How’d you do it? What did you use?
I have a roll and a half of Focal BAM that I will be putting to use in my Stinger when it arrives.
Dang, that’s stuff is expensive.
I've been considering ordering that exact stuff and doing the floor of the trunk for a while now.Dang, that’s stuff is expensive.
I found this stuff on Amazon, reviews are pretty good.
https://www.amazon.com/dp/B012B5EMGO/ref=cm_sw_r_cp_api_i_t1GZCbF4JCGVH
I used this very stuff to line the spare tire area as well as putting a layer underneath the floor cover that goes over that area. Don’t remember how much I used but it made some difference in road/tire noise intrusion. Read some as a little.Dang, that’s stuff is expensive.
search , somebody posted a thorough "how to" on this topic several months ago
I have no idea how much it would take, would 18 square feet be enough?
That depends on what you're trying to achieve.
If you're just looking to stop vibration of the panel, any coverage is better than none - even a relatively small amount will change the frequency at which the panel reverberates, and also reduce the amplitude of the vibration.
If you're looking to use it at a sound barrier, you will want as close to total coverage as possible.
just looked and didnt find it , I know someone did a good post on it though , including doors etcI tried searching before I posted this, but I couldn’t find anything. Link?
I find a couple of dead bodies stuffed in the back does the trick. Trouble is you have to get fresh ones every few days.
Don’t forget the bottles of acid.In between body runs, you can carry the bags of quicklime and bales of straw.
And then people wonder why my rose garden is so nice...
I’ll try to post some later today.Pictures?
