Andr3Stacks
- May 11, 2020
I did use the same fingers on the same handYou gotta use the same fingers at each corner.![]()
Hows the ride in comparison to the eibachs?If yours come the same route that mine did they'll also get stuck in Customs in New Jersey for a few days. At least you're on the east coast. Once mine got to USPS they still took about another week to get to me. I'm not good at waiting for stuff but the shipping communications have been really bad during the pandemic which makes things worse. On the bright side, once you get them installed you're gonna love them. I have a RWD and had Eibachs originally so I had a little more gap on the front wheel well than I liked. I lived with it until I got lower profile tires and then it got worse so decided to swap 'em out for H&R. Stance looks great now.
Pretty much the same. Besides the stance issue I had been getting a vibration especially at freeway speeds that I had read might have been associated with the Eibachs. H&Rs solved that problem too.Hows the ride in comparison to the eibachs?
Okay good to know. Trying to make a decision here. I have H&Rs on another car and it rides good. Smoother over road cracks and ripples etc.. But firmer on actual bumps. I didnt want to rough of a ride so was trying to see the difference between the two.Pretty much the same. Besides the stance issue I had been getting a vibration especially at freeway speeds that I had read might have been associated with the Eibachs. H&Rs solved that problem too.
Not really sure but they did apparently. It was fairly subtle but still noticeable.Okay good to know. Trying to make a decision here. I have H&Rs on another car and it rides good. Smoother over road cracks and ripples etc.. But firmer on actual bumps. I didnt want to rough of a ride so was trying to see the difference between the two.
Vibration? I havent read that. How would springs cause vibrations? Thats interesting.
Finally got mine on!
It feels basically no different from stock for the most part. I think the front may be softer and the rear stiffer? I'm going to install the Mando in a couple days and will play with it some more.
Over all, I like it!
I’ve read all the post in this thread. So what is the consensus on removing the bump stop for our RWD?
Thanks!
They're fine as they are. No need to cut
No they are not RWD.@K8 Stinger Store are the ones on your site RWD?
Thank you!No they are not RWD.
Only available from Germany
Need part number ending in -2
Thanks!
I just got my H&R rwd springs. And debating if I should cut a 1/4 or 1/2 a wrap of coil off the rear.Does anyone else feel the rear on these RWD-specific springs sits too high? I'm tempted to remove the rubber spring isolators to get a little more drop in the back.
that, or cut a coil![]()
Are you sure you seated them properly? Shouldn't sit that high if at all. Have you driven since installing. They should drop some once you drive some.I just got my H&R rwd springs. And debating if I should cut a 1/4 or 1/2 a wrap of coil off the rear.
thats odd, my FRONT is tuckedMy tire is tucked. I would hate to be any lower without bags.
ok I'm not the only one lolI just got my H&R rwd springs. And debating if I should cut a 1/4 or 1/2 a wrap of coil off the rear.
