Savvas, You can load your Stinger into the Water first, and if it floats, we'll go next..Anyone interested in a drive up to the big chute?
Big Chute Marine Railway
Trent-Severn Waterway, Lock 44 - Big Chute Marine Railway · 7000 Upper Big Chute Rd, Coldwater, ON L0K 1E0
★★★★★ · Historical landmarkgoo.gl
I was there this past Saturday for drag strip.. Track is next for sure.. possibly at Shannonville next Friday.TMP is OPEN!
Toronto Motorsports Park | Race Cayuga | Drag Racing | Road Coarse | Exotic Dream Car Experience - TMP
Motorcycle Lapping – August 15th – Cancelled – Message us for Options Friday Night Only ALL Haldimand-Norfolk and Six Nations […]torontomotorsportspark.com
Lol. That’s why we have airbags. No?Savvas, You can load your Stinger into the Water first, and if it floats, we'll go next..![]()
Did you try pulling your AWD fuse off to compare 1/4 mile times?I was there this past Saturday for drag strip.. Track is next for sure.. possibly at Shannonville next Friday.
Kia Stinger GT - 1/4 Mile Vs. (Challenger, BMW, Audi, Mercedes, Vette, Nova)
No I didn't. is it o.k. to do that and put it back ? No problems after or dealer know it was unconnected later ?Did you try pulling your AWD fuse off to compare 1/4 mile times?
I am sure it’s logged somewhere that the AWD is not online but the stinger is a RWD with an AWD add on. It will not even show an error code when you remove the fuse. Easily beats a C43 on a rolling race.No I didn't. is it o.k. to do that and put it back ? No problems after or dealer know it was unconnected later ?
Not so sure it was you. I think I would have noticed the red addition to your lower sides. I didn't see that on the car that I was "playing" with.That is cool wondering if you saw my car 2022
Hmmm, ok strange. Someone told me there was no stud for the bottom mounting nut (it’s not really needed anyways). Glad you couldI installed mishimoto catch can myself np
I just finished installing a Mishimoto OCC last weekend on my 2022 and there was no stud. But the hole is there where the stud be so I used a 5/16 x 3/4 inch metal screw screwed into the hole. Worked perfectly.Hmmm, ok strange. Someone told me there was no stud for the bottom mounting nut (it’s not really needed anyways). Glad you could
You’re right, that PCV hose clamp was a bitch. I got it off using a long protruding needlenose plier. They should have used a band clamp with 1pc protruding prongs on both sides, not 2 small prongs on one side like that clamp that made us say bad words.I just finished installing a Mishimoto OCC last weekend on my 2022 and there was no stud. But the hole is there where the stud be so I used a 5/16 x 3/4 inch metal screw screwed into the hole. Worked perfectly.
Getting the band clamp off of the hose at the PCV was a real bear. The tabs were horizontal and I could not properly get to them with any type of pliers. I wound up working the tabs around to a vertical position, taking the engine cover off, at which point I could easily get pliers on the tabs and move the band clamp back. The rest of the install was very easy.
