Zotto
Was that just springs?
you have the link?
you have the link?
you have the link?
Did you pay for the install? or did you do it in your garage?I got mine on eBay for $240 with free shipping.
I had my springs installed by a tire shop for $300, plus an extra $79 for alignment. A few weeks later I had a mechanic that works on hod rods and imports install the front and rear bars for $200.
If you have the right tools you could do it yourself in your garage, but it looked like a major PITA to me. Car has to be lifted and wheels removed, and access is real tight to the bolts.
That's about $515 Aud springs and alignment. Just had mine installed and a alignment- $550 included tax.I had my springs installed by a tire shop for $300, plus an extra $79 for alignment. A few weeks later I had a mechanic that works on hod rods and imports install the front and rear bars for $200.
Personally I didn't have my head under there when he was doing it. I was conducting some retail therapy many miles away.did the shop remove the spring isolator (the "sleeve" of extra material on the 1st coil of the factory springs) and install this on the eibach springs
This ended up being way longer than I was expecting but I know a lot of people are looking at these mods and I wanted to answer as many questions as possible.
Last week I was able to have the Eibach Pro-Kit Springs, and Front and Rear Swaybars installed.
First I want to thank Jeremy Sexton from Car Mods America for getting me the parts. I was having trouble finding all the parts in stock and made a post of FB and he reached out and got me set up with everything at a great price. They are still setting up their website with parts but you can reach out to him at Jeremy@carmodsamerica.com
I also want to thank Vinnie from Vinnie's Exotics in Baton Rouge. He took a break from working on Ferraris, Bentleys and Porsches to work on my Kia. Luckily he saw my Stinger at the detail shop around the corner from his shop a few months ago and then bought his wife an AWD GT1.
Springs: The springs are listed by Eibach as being for the AWD Stinger. However I confirmed with Eibach that they fit and function fine on the RWD car. As of a couple weeks ago they were in the process of updating their documentation, but it looks like the website still hasn't been updated.
The ride is firmer however it is not harsh. My previous car was on fully adjustable H&R Coils at about 75% firmness, this is no where near that harsh. But it is a sportier ride and moves a bit away from the GT style.
The biggest difference is the "float" over bumps is pretty much eliminated. Previously when the car would hit a bump the spring/shock would compress then bounce 2-3 times to help reduce the impact of the bump which felt like "float". The bounce has been reduced.
Also on hard acceleration and braking the pitching back and forth has been eliminated. This makes having to brake and turn (i.e. evasive maneuvers) feel much more under control. Hard acceleration has lost some of the squat then go feeling, it just goes.
Drop Measurement - this is a ground to fender measurement with a 1/2 tank of gas.
Rear:27.5"
Rear: 26.5"
Overal: 1" (1.125” after settling, see update below)
Front:27.375"
Front: 26.5"
Overall:0.875" (1” after settling, see update below)
The drop is sufficient enough to make a difference, however it does not look obviously lowered. Its a good look if you are not trying to draw more attention than just people admiring how good the car looks.
Update: The car dropped another 1/8” front and rear after 2+ weeks and 300-400 miles.
Eibach Pro-Kit Springs and Sway Bar Review w/ pics
Sway Bars: The rear sway bar is a pretty straight forward install, remove the end link, remove the mounting bracket, slide sway bar out from the side. This can probably be done on jack stands by just taking the wheels off. The most difficult part looked to be getting to the drivers side mounting bracket because of the fuel lines. Just use a small ratchet and you'll be good.
I had the rear bar set at the soft setting to start. Switching to the harder setting is easy, remove the bolt to the end link and move to the harder setting. This might be able to be done without taking the wheel off which would make changes at the track very easy.
Overall the car is very flat now in the corners. As much as the the Stinger got praise for its handling in early reviews it leaned quite a bit in the corners. That has pretty much been eliminated at this point.
One change that Im not sure if is due to the Springs or the Sways or a combination of both, is that previously going around corners with bumps the car felt unsettled. Now the car had no issues.
Overall Impressions: Ive had Springs/Coils and Sways on every car Ive owned so I knew I would be happy with this modification and it did not disappoint. It may take away a bit from the pure GT style but in o way is the car uncomfortable. It even got the wife seal of approval, as we were in the car this weekend she asked if I was happy with the changes and I asked her if she could tell a difference "feels the same to me".
The only issue I have now is the headlights are aimed too low, which is common after changing the suspension. I'll just need to adjust the headlights up slightly.
Alignment: Obviously once you change the springs an alignment is needed. If you have a Firestone near you I would suggest buying their Lifetime Alignment. Its $180 if you buy it online and gets you free alignments for the life of the car. Basically if you get 3 alignments its paid for itself.
I ran into an issue with Firestone not having the alignment specs for the Stinger yet. Surprisingly the Kia dealer didn't either. Luckily this post here had alignment specs (thanks @Killa200) and I was able to give these to Firestone and they got everything straightened out. The rear toe was really bad so Im glad I went the next day after install. Ill get it checked again in about 300 miles once the springs have settled a bit more.
Now for the pics
TLDR: Buy Springs and Sways, you won't be sad
I had a simple question, I am contemplating this mod kit as well... as I to have always used Eibach Springs and have been really impressed!! The rear bar is probably gonna give you the most bang for buck seat of the pants real corner carving enhancements! My question is this, how easy is it to adjust the LED headlights on it? Not even sure that a 1 inch drop is even gonna be significant to make an adjustment??? Thanks in advance for the in depth review!!
I removed one of the airboxes, but realized that a skinny long Phillips screw driver does the job just as well.Actually the headlights dropped quite a bit for me. Adjusting it is easy, a bolt on the back of the headlight. Search for a “headlight adjustment” thread with a post from me and I have a detailed write up on how to do it.
If you can get that to work good for you, I couldn’t get any movement that way.
