washguy
Too funny ive got tubi exhaust on my z06...and the sound and performance is awesome....glad it worked out...woot woot...Wash
Ya, prices are all over the map though...try Alvin at ART Performance Australia- seriously.5.4K ....![]()
Do you need any sensors ? I’m about to install mine and I had them for awhile and think I remember someone saying you need a defouler or soemtbing ? To make sure check engine light don’t come on ?Got it all finished, this is what I discovered: 2 nuts at the top flange of each downpipe are 19mm. 2 nuts at the bottom flange of each downpipe are 19 mm. 6 bolts across the cross brace are 14 mm. When installing the downpipes, you will reuse the upper 19mm nuts on each side, and the two middle 14mm bolts on the cross brace. Provided with the downpipe (in the case of Jun B.L.), are four 14mm nut/bolts for the cross brace, and four 14mm (2 each side) nut/bolts for the bottom flange of each downpipe. I used an impact gun and torqued them down pretty tight, no stripping out and no leaks.
