boosted1g
Sustaining Member
Negative. With resistor mod the stop and go is always disabled.Is the ISG (Idle Stop and Go) button still functional if you do the resistor modification? Can you still turn ISG (Idle Stop and Go) on once the car is running?
You would have to put a switch button somewhere and then wire the switch in parallel with the resistor so you could bypass resistor as desired.
I was concerned about this loss of functionality but decided to do it anyway and haven't regretted it in the almost 3 years I have had the car
