stoopid
1000 Posts Club!
Are you being intentionally obtuse?Who is dumping chemicals. Instructions say 1 second bursts. Have done it twice so far.
How did you go using this cleaner.I’m trying this tomorrow how did it work? Using that intake port?
The hose clamp just has a cover over the regular bolt/screw headOkay finally set up to spray cleaner Checked to see what tools I need. Is there a special tool for the main air intake worm gear clamp? It is not a hex shape or an Allen head. Hate to damage clamp with channel locks or vise grips
the smaller line near the fire wall appears to be a little different than my car. There are two lines in the area. Not really clear, on the picture. Pulled cover from motor. One goes directly into the plastic intake. The other connects to some other line and goes who knows where. Guessing I should use the line that connects to the plastic intake. Am I wrong?
thanks
why on earth are the hex heads covered with this "cap".The hose clamp just has a cover over the regular bolt/screw head
Most like is what you said .. a type of breakaway bolt cap at a specific torque.why on earth are the hex heads covered with this "cap".
Are they some sort of torque limiting snap off one time use thingy that snaps off once the desired torque is reached during initial assemble?
These are the caps - removed from the hose clamp for a visual reference.
did you just detach the hose part or does the circular part come off?See picture attached. Perfect spot to spray into. Just make sure to wear some gloves, the engine bay gets rather hot when spraying
Thanks!I disconnected the hose. It backed of the hose barb easily. Sprayed into the barb on the circular part keeping a finger covering the remainder of the barb opening. Found out this Helped in maintaining about 2000 rpm. Gloves absolutely necessary. Had to change hands several times and also change gloves.
Maybe the last time, more of the CRC pooled up somewhere causing it to smoke so much and backfire. On that car I sprayed it into the air cleaner box.Used CRC on my sons stinger same result not much smoke ran smooth the key is continuing to useAt least once a year or more depending upon your mileage
