Cellphone gets warm on cordless charger pad
Mine gets hot too, but not at all worth my wireless anchor charger. I'm try the rear ac trick to see if it helps
Mine gets hot as well. Hot enough to shutdown my spotify when plugged into the USB port. I"ll will definitely look into the rear vent settings.
Mine gets hot as well. They fixed it with the facelifted Stinger. It now has a wireless charger with a built-in fan.
My wireless charger in my 2021 GT stinger heats iphone so much its goes into shutdown mode. Cant use it. Any ideas?
On my 2020 Stinger, I usually turn one or two AC vents towards the wireless charger to cool it off a bit. Does your wireless charger have ventilating holes on it? The 2021 Stinger got the facelift with the updated wireless charger in Australia.
Just bought a 2022 GT2 and the wireless charger in this thing is virtually unusable, even with the rear seat vents set to cool. What the heck..??
It charges my Android with no problem other than insane heat but my gf's iPhone does not seem to get any juice to the battery. Very strange indeed! :coffee:
If her iPhone is in a case, that can interfere with wireless charging.
I thought that too and there was still no charging even after removing the case. I have noticed that at times the car-charger fails to charge even my phone at random times. Oh well. Will figure it out.
Thanks btw! :thumbup:
I've had my 2022 Stinger for about 3 weeks now and I'm having the same issue. My Galaxy S10 won't charge. It was ok the first 2 weeks, then it started making my phone hot & now it won't charge at all. If you find a solution please let me know.
Good to know, thanks. I'll check that out. :thumbup:
The vents have nothing to do with it. I've tested the surface temperature of the charger without my phone on the charger and it registered 104 degrees Fahrenheit. Ambient temperature for iphones is between 32 – 95° Fahrenheit.
2019 and mine gets super hot too. I use like a 3 inch usb charging cord and lay the phone in the tray sideways so it's not on the charging pad.
Im going to be insulating my wireless charger using stick on heat deflection tape tonight and see how that goes.
get a samsung phone;)
wow, didnt know this was a thing. i dont have problems with my charging pad. i have a case on my samsung phone too.
