JSolo
2500 Posts Club!
Did they say why the coil/boot failed?
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
My guess would be…he launches a lot on stock plugs that are likely unevenly gapped. Just going by the fact he uses a Kia tech for a machanic.Did they say why the coil/boot failed?
And that is "hard" on coils???My guess would be…he launches a lot on stock plugs that are likely unevenly gapped. Just going by the fact he uses a Kia tech for a machanic.
They did not. The service advisor said that they fail rarely and anytime. A hundred bucks a pop when it happens isn't exactly going to break the bank.Did they say why the coil/boot failed?
I have no idea. But if you’re flooring it with a cracked plug I doubt the coil is happy.And that is "hard" on coils???
My theory, backed up by this experience, is essentially what you said. I opined that one bad plug out of the batch of replacements late last September damaged the coil pack, which ruined the replacement-replacement plug in January: that plug behaved far worse than the "chugging" plug starting in October. But just as possible as a faulty sparkplug, is a failing coil pack first, destroying the new plug: or possibly this was already happening (in the beginning stages) with my OEM plugs and I just hadn't experienced "chugging" yet, but the car was down on power yet still smooth-running until the spark plugs change disturbed that: I had remarked quite some time ago, how my butt dyno was now used to the acceleration, but possibly a slow and steady failure of the number six cylinder coil pack was going on. "Chicken and egg" situation, coil pack or plug failed first?My understanding (and someone can correct if im wrong). An ignition coil is nothing more than a transformer of sorts. There may be some electronics on the primary side (low voltage side). Maybe the bad plug caused a higher resistance to the coil which meant greater load on it. Resulting in greater wear - meaning not able to produce a good spark under load or heavy load.
I don't believe there's a maintenance interval for ign coils, but they do wear out/go bad over time.
Neither had I, that I recall, until this past six months.Never experienced a failed coil or plug on a car (yet).
WTH is that?The optispark failed.
My code was cylinder 6 as well dont spend money on coil packs untill you upgrade to hks plugs gapped .028 that is what i run and since changing plugs no missfire. Also i only use good fuel no stop n shop or costco fuel , arco, sinclair ectBumping this thread. Just bought a Kia Stinger GT1 2 months ago, with 39k miles on it now, and after some spirited driving in the LA Canyons(launched it once) im now having misfires.
First got a P0306 code (Cylinder 6) and took it in to the Kia dealership to have the spark replaced. 2 weeks later they replaced the spark plugs in cylinders 1,2, 4, 5, and 6 under warranty.
Car was running fine for three days until coming back home, I was on sport mode and pushed the throttle, noticed chugging and quick engine light. Took it to OReillys and got a P0304.
Knowing what I know now from reading this forum I will be taking it back to Kia tomorrow and seeing if they will do a proper job and replace the coil packs and plugs.
Sorry for the long spiel.
Costco is good gasoline. You don't recommend a "good fuel", just diss several not good ones (in your opinion).My code was cylinder 6 as well dont spend money on coil packs untill you upgrade to hks plugs gapped .028 that is what i run and since changing plugs no missfire. Also i only use good fuel no stop n shop or costco fuel , arco, sinclair ect
Replacing No. Six cylinder coil pack fixed my sparkplug problem, which was that the fouled coil pack was ruining each replacement plug in c. two weeks: it wouldn't matter what the gap is.
