I daily drive my 22 psi ECU tune. Aside from keeping it happy with Octane its not a big deal. If you stay off the gas you stay off the boost. Its always ready to pounce but I normally drive it mellow.
A lot of time I just kick over to map1 or map2 for normal driving, or even map4 (VALET) if I want to let someone else drive the car. On the fly map changes are a huge feature. Can't wait until we are able to program them in to factory buttons on the vehicle like we do for other platforms. Then you don't even need your phone to change maps!
I agree. Although I don't mind using my phone that would be a bad ass feature if the phone was not necessary.
When the wife drives the car is always on map 0. When I daily drive the car to work I usually run map 1. When I am at a stoplight and I see some mustang or Camaro creep up it goes to map 2. You already know when I am at the track I use map 3 and Map 5.
That's just peak. It always tapers as the RPMs climb. I hit 22 in first gear, 21 in the first part of 3rd and 4th gear. 3rd tapers to about 17 PSI. (this is all on 1/4 mile runs so RPM for 3rd and 4th gear start in the high 4k RPM range. Second gear starts in the low 5k range so less boost)
Just noticed my 11.87 run only hit 19 PSI in 4th while other runs hit 21 PSI. That explains the extra 2 MPH trap on some runs. Looks like the 11.87 time is going to drop a bit.
Looking at the trap speeds it would appear most are running about the same boost, or at least in the 20-21 range. +7 PSI on JB4 is 21 PSI. And Lap3 pro hits 20.7 on map 3 I think. Others think the JB4 logging reads boost about 2 PSI low.
I was thinking I need an E30 tune so I can compare to Jb4 on level of tune.
They wont provide any info into the ECU tune is officially released. There very low key. I though about kidnapping the tuner before and make him tune my car since I got a track event on May 5th. (Disclaimer I am clearly joking here, I don't want to get banned from this thread.)
