ARK GRiP Exhaust Review
Drone only shows up once the exhaust is warmed up, so you'll need to drive for at least 15 min to hear it.
Also the enhanced engine sound only pumps engine noise through the speakers (synthesized) and makes the engine RPM hang a little bit when you let off the gas under moderate acceleration.
The plus side to the exhaust is there is quite a loud "Snap"/"Burp" when you either launch the car or shift from 1st to 2nd in manual mode with Traction and stability control off. For some reason if you turn off stability control completely the car WILL NOT automatically shift during manual mode and you can go a little further in the RPM's. I find if you shift from 1st to 2nd around 6400-6500 you'll get the "Snap"/"Burp" I'm talking about. Auto mode or manual mode with everything on usually shifts around 6200-6300 so it doesn't generate that noise.
Hope this helps.
That markes sence in retrospect about more drone when warm. My short drives to work where fine but longer drives got loud. 1500-2000 is the most common rpm range for normal city or highway driving. But if you live in sport mode with an occasional down shift you can avoid most drone.
Hope this helps.
Thanks Jdm that is of some help. That might make sense as I only drove the car 10mins down the road. It then let cooled down before I demonstrated it again.
Thanks D-C, had coffee with fellow Stingee Stinger Gt ss and gave him a sample of the Ark. Would you believe for the life of me I couldn't replicate nearly the amount of drone I had experienced 2 days before. My wife even suggests the exhaust is not even remotely noisy! So since getting it fitted on Friday to today Monday it has settled so it seems??
No I didn't turn the sound enhancer off, I only remembered when I put the car in the garage. I'm thinking whether with 4 adult bodies in the car today whether crazy as it appears we absorbed the sound?
Can you wait until the weekend for the final analysis? I won't be driving it again until then. I can do the test then.
Today the exhaust met with approval of 3 others. If you are really pressed for time message me and I'll see if I can take her out before otherwise I'm off shift on Saturday PM. Cheers.
That certainly sounds a lot more positive Ozstung, yeh I can wait my cars booked in for Friday the 12th so I certainly have some time.
I'm glad to hear it seems to be less of a problem than first thought and others have given it the tick of approval.
Thanks and I appreciate your feedback
Cheers
Dyll
Hope this helps.
Thanks JDM MAN for your informative response. My main concern is driving on the freeway every day around 110kph, but it sounds like if I turn traction control of and have it in sports mode the revs will sit a bit higher and out the problem drone band.
Cheers
Dyll
Hi it seemed like the ARK was one of the better ones for low drone,
Ark grip exhaust is well known for its horrendous drone in the community here. Some people do not mind but the drone is definitely bad.
Hi Xot1
That's a bit concerning. Thanks for the info
That's strange my dealings on the forum lead me to believe that the Ark grip had possibly the least amount of drone. And I concluded with the twin hemholtz resonators that these helped significantly to reduce drone. 1500 revs is the figure in which the drone starts at and it at it's most offensive.
After yesterday's short trip with very little drone other members have suggested drone is at it's worst once the vehicle has reached operating temperature. I'm pretty sure sound deadening material if need be in the boot will work. This is because it should stop the sound vibration which I believe is the cause. To me it's not the sound level but the vibration sound at 1500.
Hi Ozstung, I thought exactly the same that’s why I ordered and plus it sounded like one of the better exhausts to me. I think I’ll just suck it up and put up with the drone in that rev range. Hopefully it beds in a bit and reduces over time.
Thanks for your feedback
I have heard that with secondary cat delete the drone is reduced significantly.
  • Like
Reactions: D-C
Thats good D-C, if it's any consolation I took my wife out for a drive yesterday now she's normally reasonably negative as are quite a few 50 year old woman :D , however to my astonishment she said the exhaust was good and much better than any other of the other incarnations I've had on other vehicles. When I demonstrated drone at 1500 revs she said it was minimal. Phew that's a relief.
Hey Ozstung certainly is consolation. Good to hear thanks mate
Are you serious? Who said this? Ark has some drone, not much, and is moderatley loud. Probably middle of the road. Removing Cat makes exhaust considerably louder so hard to believe it would reduce drone.
I have not witnessed it myself but several people on local forums experienced the same reduction in drone. I can only trust their words...
Be sure to share cool stuff from Korea like after market turbos and best 1/4 mile times!
1/4 Mile Thread
I went to a car meet recently (my first one! :D) and there was like 4-5 other stingers.To my surprise, most of them were tuned to 420~470WHP :eek:, and my car was the only "stock" car (I did only did the exhaust).
Actually I’ve heard this also, I’ll report back if it’s true once my SSR Dp get here. Drone for me really isn’t as bad as everyone keeps saying it is. Maybe it’s the speed limit differences between locations idk. It def is noisier at low rpm acceleration.
That's certainly interesting xot1. It would give me a good excuse to get rid of the secondary cats.
I would want it hear it first hand. The Ark doesn't really drone as much as its loud. Removing the cat will make it louder.
Ozstung did you notice in power difference with the exhaust ?
Cheers
Dyll
Hey Guys!
Glad to see so many users are enjoying their ARK GRiP exhaust system! From our personal experience with the competitors' Stinger systems and user reviews, we can confidently say we produce the least amount of drone for the Stinger out of the exhaust systems that actually increase the volume/note.
Exhaust 101 - the only way to increase flow is to either delete obstruction, like a cat/resonator and/or increase the diameter of the piping so that more exhaust fumes can flow out faster. This has to be done without deleting the necessary back pressure but that's for another post. ;) With that being said, the more room air has to move around the more vibrations the air can make. We combat this in two ways. Helmholtz canisters can fill in at lower exit speeds increasing the travel those fumes need to escape and thus reducing drone. Secondly, a thick steel to reduce the amount of vibration that can escape into the cabin. The thicker the walls of the piping the less the vibration is felt in the cabin. There is a reason why stock exhausts produce hardly any drone. They are heavy (thick) and they are smaller in diameter.
Lastly, we've built headers, downpipes, and test pipes for a lot of vehicles and although power and torque will increase, you will absolutely experience an increase in loudness, raspiness, and especially drone. We're mentioning this for those considering deleting cats and so forth.
The amount of acceptable drone is 100% subjective. The drone can be too loud for some and for others the same volume of the drone is tolerable but the pitch of the drone is wrong for them. We will always try to minimize the drone to a small RPM range without sacrificing the power increase. Drone is part of the package because of the type of upgrade you're going for. The only way to eliminate drone is to keep it relatively close to stock and then we ask ourselves...what's the point?
Here at ARK, we like to focus on three things. How does it sound from the outside? We like a deep growl through the lower RPMs and an increase in pitch during WOT. How does it sound from the inside? Is the drone in the smallest RPM range possible? And lastly, are we increasing the performance of the vehicle? If we are satisfied with those areas then we move on to production.
We are here if you have any further questions about our GRiP exhaust system for the Kia Stinger.
Thank you all!
ARK Performance
