Are AWD and LSD mutually exclusive?
Clearly Canadian
Edmonton Canada
Confused...are AWD and LSD mutually exclusive?
Will I notice the difference?
Only if you're on the track or driving like you should be. :D Or if you've got poor traction, especially when one rear wheel has traction and the other doesn't.
This refers solely to RWD, not AWD.
So is Subaru and those cars drive in the snow like they are sled dogs.. :D
I'm accustomed to Acura's SH-AWD it's sooooo goooood.
In regards to the article above: I don’t understand all of the mechanical jargon mentioned so maybe someone on this forum can interpret.
I hope the torque vectoring is well-integrated with the AWD because it doesn’t make much sense to brake a wheel under power.
I can’t imagine that the system will help much on ice compared to the non-brake based vectoring systems.
Honestly I’m a little disappointed with it on paper though maybe my opinion will change when I have a chance to drive it myself.
If one tire is spinning faster than the others under power, that wheel has less traction than the other tires. Braking on that wheel will force the open diff to send power to the other wheel that has more traction. It accomplishes the same thing as a LSD, only in a different way.
If one tire is spinning faster than the others under power, that wheel has less traction than the other tires. Breaking on that wheel will force the open diff to send power to the other wheel that has more traction. It accomplishes the same thing as a LSD, only in a different way.
If that’s how it works it doesn’t sound that bad :thumbup:
Torque vectoring takes it one step further where it will also push more power to the outside rear wheel. That wheel needs to travel faster than the inside wheel and it has more traction as it has more weight on it. It also supposedly helps push the car through the corner. I know Subaru has been using it for years and their cars do pretty damn good in the snow..
Shall we have Subaru/Acura flame war on the Stinger forum? :laugh::thumbup:
