Clearly Canadian
Confused...are AWD and LSD mutually exclusive?
I believe In the Stinger they are.Confused...are AWD and LSD mutually exclusive?
I doubt it. I think either the RWD or AWD will drive great.Will I notice the difference?
In the snow AWD with torque vectoring will be way better than the RWD with the lsd.Will I notice the difference?
So is Subaru and those cars drive in the snow like they are sled dogs.....although the torque vectoring is brake-based.
So is Subaru and those cars drive in the snow like they are sled dogs..![]()
Watch this: (subie in the snow)
If one tire is spinning faster than the others under power, that wheel has less traction than the other tires. Braking on that wheel will force the open diff to send power to the other wheel that has more traction. It accomplishes the same thing as a LSD, only in a different way.I hope the torque vectoring is well-integrated with the AWD because it doesn’t make much sense to brake a wheel under power.
If one tire is spinning faster than the others under power, that wheel has less traction than the other tires. Breaking on that wheel will force the open diff to send power to the other wheel that has more traction. It accomplishes the same thing as a LSD, only in a different way.
Torque vectoring takes it one step further where it will also push more power to the outside rear wheel. That wheel needs to travel faster than the inside wheel and it has more traction as it has more weight on it. It also supposedly helps push the car through the corner. I know Subaru has been using it for years and their cars do pretty damn good in the snow..If that’s how it works it doesn’t sound that bad![]()
Hahaha, probably not. I used to be a huge Acura fan...Shall we have Subaru/Acura flame war on the Stinger forum?![]()
