2 USBs front console
You are all lucky that the different centre console made for the left hand drive cars.
I've not been able to find one for right hand drive, looks like I'll need sellotape and cardboard...
Maybe you should drive on the correct side of the road instead. :whistle:
What a great idea to run that hub! However, I don't like the idea of drilling....
How hard would it be to use a USB splitter behind the dash area, plug one back into factory slot and run the other one to the center console?
During the cupholder upgrade I took Stingergtandme (His YouTube handle) advice and added many USBs in my center console. Can charge the neighborhood now:geek:View attachment 4346
Great USB HUB mod!
Is that USB hub 3.1? Do you know if USB data/Android Auto will still work when you have other connections attached to the hub?
Has four 3.0s and one fastcharger (red). Have not tried it but USB data should work when other devices are connected to the hub as they are 2 seperate ports beung used.
bo
Both holes are small and not visible at all. All wires are completely hidden and the sliding console tray can close all the way.
Thanks for the input.
Would you share your experience after connecting Android Auto/Apple Car play to the hub when you have other connections to the hub simultaneously? =)
Right now the hub is connected to the USB charging port not the data port, but I will switch the hub plug to the data port and see if AA works while charging my Samsung tablet.
Cool!
Thank you Rango! =)
Drilling two small holes vs taking the dash apart...ill drill the holes. Go slow and know that the drill bit will "walk" once it bites the plastic. Then use a higher speed to clean it up.
Americans love their big gulp.
As long as it fit a cup of tea, us Brits will be happy.
As for the Canadians, I can't think of a stereotype except for Maple syrup or Bacon, but neither of them work really....
Californians love their iced Chia lattes and fresh beet juice. Could ever do away with my cup holders.
Rango - did you find a USB hub that allowed you to plug in multiple USB devices for data, not just charging? In my own limited experiments (2 hubs), this did not work - even a single USB device behind a hub was not recognized by the Stinger.
