robz32
Texas Stinger Swarm
Awesome results Terry, great to see the improvements and support you are giving the platform.
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Yeah i add 3 gallons every tank and it did made a noticeable difference so if its tuned it'll be much betterE85 is great stuff. 30% mix with the JB4 and fuel control does wonders.![]()
So at that kind of performance boost are you at all worried about the other parts of the car not holding to the added stress of the engine? That's an amazing amount of horse power gains. Can suspension and transmission take that kind of abuse?
I’ve heard 600-800 and here is one post with someone explaining the 800hp/tq limits.So at that kind of performance boost are you at all worried about the other parts of the car not holding to the added stress of the engine? That's an amazing amount of horse power gains. Can suspension and transmission take that kind of abuse?
Definite possibility, however I remember reading where a Korean tuner (possibly Lap3/Pross), took apart a Singer motor and transmission and were blown away by the level of overengineering of the lower part of the motor and the transmission internals. I also believe that an American tuner researched the power and torque limits of the engine and transmission and the numbers that were quoted were 800 HP/800 lb. ft. if I remember correctly.
If that is, indeed, true, then that is EXTREMELY impressive and sincere kudos to the Kia engineers for that.
Stupid question that's probably already been asked. Can i run map 1 on stock plug gap until I have time to order new plugs/install them?
If all my focus rs parts would hurry up and sell...
You could and you might get lucky and not have any issues.
BUT when we first started the beta testing there were a few of us who left the plugs stock and had issues running map1. A few forum members ended up having to take their cars in for cracked plugs/damaged coils.
Some of us were lucky, though. I ran mine with stock gap for a few hundred miles on map 1 and didn't have any problems. The only reason I re-gapped my plugs is because of the troubles others were having.
In other words you could try it out and may get lucky. But it's definitely a gamble.
Cool, will it foul anything or run rough?
1) Run the highest octane you can, even on stock tuning, and definitely when tuned
2) Denso 5346 gapped at 0.022", but the expensive HKS plugs gapped at 0.022-0.028" have been used by customers also. I just prefer the cheaper plugs.
3) Yes
Not sure for full e85 compatible but you will need a tune for that.Is this car capable of full E85?
Thanks, good to know. I will probably just wait and do them at the same time. I had to swap the plugs on my RS 5 times in 10k miles so this shouldn't be an issue.
Stock ecu can adapt to only 3 gallons of e85 mix anything more will be a major hit on mpg and no difference on hp/tq
Also give it 3 good tank mix before ecu fully adjust and do some wide open throttle will help it learn faster
I've been told that your current pricing will be going up next week?
