3.3TT Declined to do Alignment
StingerT303
Denver, CO
I need to do an alignment now that I did the lowering springs and rear sway bar (looks and feels awesome)
Iprinted out the alignment specs and took it to Brakes Plus and they said they cant do the alignment? They cannot type in the new alignment specs and because the car isn't in their system they say I need to take it to the stealership.
Anyone else get rejected from doing the alignment?
Yeah this is normal for new cars. They should be able to update their machine with the specs but need their rep to come out and do it.
I took mine to a shop that aligns a ton of high performance cars and does lots of high end frame/alignment work to include Pikes Peak Hill Climb cars, and they were able to do it by just inputting some other car model and then just getting the specs to match what I gave them. They added some fractions of degrees here and there to match the type of driving I do as well. I can imagine that a big chain probably won't do that, but find a good independent shop with skilled wrench turners and you will be golden.
how much was ur alignment if u don't me asking?
Took mine to the dealership and they refused. They said the shop manager did not want to do the work because the suspension was modified. I'm assuming for liability purposes? Took it to my Mechanic a few days later (the shop is far from my house) I gave him the specs and he said it was the same as the K900
80 dollars. Couple bucks more than some other places but they nailed it.
Didn't you take yours to Firestone? If so did you have to give them the specs?
I'm taking my car to a suspension shop next week to have them installed and I have a feeling they won't be able to do the alignment. I have a few Firestones in my area though. If you gave them the specs I wonder if it went out nationwide when/if they saved it to their database.
Yeah I did, they used an Optima or K900 and adjusted from there.
They have a Hunter alignment machine and their Hunter tech has to update the machine to get the Stinger specs in there. Not sure if every Firestone uses the same equipment though.
Info about the alignment from other fellow members who installed the Eibachs springs:
"KLR STINGER:eek:nly the rear has camber adjustability as far as I can tell. Front lower arm and compression arm look fixed. The rear lower arm has an eccentric crash bolt and has adjustably. I believe the only way to get front camber adjustability is with new upper strut mounts(aka camber plates)"
"Mr Skillet: Dealer tech told me the stinger only has rear camber adjustment, nothing in the front."
So, I am confused now.....
Im in Colorado too. What shop was it?
UPDATE: Took it to the dealership. They said they dont even have the specs to align the Stinger or K900 yet...
The good news is I only sat around for 90 minutes for them to figure that out...
What are you confused about? Those two statements are saying the same thing. Stock, the rear has camber adjustabilty, and the front does not. The only way you are going to get front camber adjustability is through the use of an aftermarket suspension.
My confusion is about these statements and the post were a fellow member attached a picture with the alignment specifications (normal and high suspension type), front and rear, toe camber & caster, supposedly used in aligning his car. Other Stinger owners who have replaced the springs mention to have performed an alignment in suspension shops......
Had Eibach springs installed and a wheel alignment. My suspension guy told me to stop reading the forum:laugh::laugh::laugh:.
Photo’s..!!!!
Front suspension is adjustable on 99.9% of cars, just usually not camber. Some shops won’t touch a car if it’s not in their database for liability reasons. It’s can be done but sometimes you just have to find a shop who knows their stuff and can get it done.
I need to wash the car before it comes on here its filthy covered in drought ravaged dust.:D
Oh ok if you have too, just hurry up....lol:rofl::rofl::rofl:
Don’t waste your money on nationwide chain alignment shops. Find a local frame and wheel alignment business and take your car there. They are typically professionals and charge the same or less than the useless chain shops.
These are typically the businesses that custom car and lifted truck folks will take their vehicles to.
