Kamauxx
5000 Posts Club!
- Jan 28, 2018
most cars won't show 0 miles to empty but what does Stinger show as it runs low on miles to empty?? My light has never come on so I don't know
that's exactly when mine is coming on.Mine comes on at 37 km to empty. I have no idea why it is so oddly specific but I have noticed twice now that 37km is the trigger. For mine anyway.
37km to empty seems really low, not sure I’d want to risk that given at 50km to empty I only had 2.7L left. Based on that it should be down to 2 or just under for the additional 13km. It’s a big risk of running dry. My old Commodore that the Stinger replaced used to come on about 70-75km to empty.Mine comes on at 37 km to empty. I have no idea why it is so oddly specific but I have noticed twice now that 37km is the trigger. For mine anyway.
Yeah I think it’s wrong too. The fuel bowser said I took 57.3L so either it’s out and I’m getting ripped off on fuel or the car is out. I’ll still get them to check it at the first service just to be sure.If you only had 2.7L left I’d say the 50km figure was wrong. Memory is hazy but I think I still had about 4-5L left when I filled up shortly after light came on. The first warning light on my SSV used to come on with about 50 km to go and the second would come on with about 20 km to go. I didn’t waste any time getting to a servo if the second light came on.
And if the sensor bottoms out with about 6L remaining and by the calculations based on what the bowser said I put in indicating that I had just over 2L left in the tank it would then by your logic mean the sensor is faulty which is what I’ve been saying. I’m well aware the warning light doesn’t mean it’s time to fill but if you read my original post I said the DTE was 50km the needle on the gauge was on E and the warning light still hadn’t activated. Then when filling basic maths indicates I was down to 2.7L of fuel. So either my gauge/sensor is faulty or given the posts by some others on here and how low theirs has gone it would appear perhaps Kia might have set the tolerance too low. Either way it’s worth getting the service centre to check next time I’m in and worth other members keeping an eye on with their own Stingers to avoid running dry and needing a tow.The Low Fuel Warning Light is not meant to indicate it's time to fill up, it's to warn you that your fuel is lower than you should have let it get to, which is not a normally expected condition. The fuel level gauge and DTE are meant to give you clues as to when you might want to fill up.
Unless something is different about the Stinger, the lights comes on when the fuel level sensor "bottoms out" so to speak - it's below the range where it's designed to operate and show the fuel level in the fuel gauge. The DTE calculation uses your current and average fuel consumption numbers and the level sensor reading to calculate an approximate range. It does not include the additional fuel below the sensors working range, because it doesn't know how far into that "reserve" you've gone.
If you look in the manual, it is saying that you might need to put in more than six liters for the gauge to register the change. That implies that the sensor bottoms out at around 6l remaining.
And if the sensor bottoms out with about 6L remaining and by the calculations based on what the bowser said I put in indicating that I had just over 2L left in the tank it would then by your logic mean the sensor is faulty which is what I’ve been saying. I’m well aware the warning light doesn’t mean it’s time to fill but if you read my original post I said the DTE was 59km the needle on the gauge was on E and the warning light still hadn’t activated. Then when filling basic maths indicates I was down to 2.7L of fuel. So either my gauge/sensor is faulty or given the posts by some others on here and how low theirs has gone it would appear perhaps Kia might have set the tolerance too low. Either way it’s worth getting the service centre to check next time I’m in and worth other members keeping an eye on with their own Stingers to avoid running dry and needing a tow.
@eflyguy no problem mate I read it at the end of a long day and thought you were trying to mansplain the fuel gauge to me. No bloke wants to be mansplained by another blokeMy post wasn't directed at you specifically, and I don't disagree with you either.
If DTE is coming from the assumption there's 6l or more left (which it appears to be) but then the sensor trips the warning light and only 3l is left, that's a problem.
 anyway no drama, I actually agree with what you said just took it the wrong way.
 anyway no drama, I actually agree with what you said just took it the wrong way.... but i would like to see a low fuel light based on volume and have it be consistent.
Too late implies it actually comes onI think we're finding that it is indeed consistent - consistently TOO LATE!!!!
 ....have yet to see mine ever!
