Caveat emptor. Right there, you've said enough to make me go away. And besides, I like the Stinger's "spoiler". It was designed with it to go fast and stay stable. I can testify that it works as designed.
It is part of the overall aerodynamics. How do you know that it doesn't "do" anything? Do you have the windtunnel specs?The Stinger's "spoiler" doesn't do anything.
I completely disagree , its the perfect place to put a rear spoiler !! BawaaaaaNo, I have eyeballs though. The thing you call a spoiler on the Stinger's lid isn't functional.
Of course it is! Go well over a hundred miles per hour and every curve in the body is "functional", either pro, con or neutral. Neutral is always good. Con is always bad. And pro is always best. If the "spoiler" only contributes a little bit to the stability at speed, it is still doing something either neutral or a bit good. If you change the diffuser there will be one of the same three possible things happening. If you add a bit more width and uptilt to the spoiler, the same three things are on the table.No, I have eyeballs though. The thing you call a spoiler on the Stinger's lid isn't functional.
I treat spoilers as cosmetic, keeping within speed limits does not need down force on the rear wheels. And, the Stinger looks pretty good as is.Of course it is! Go well over a hundred miles per hour and every curve in the body is "functional", either pro, con or neutral. Neutral is always good. Con is always bad. And pro is always best. If the "spoiler" only contributes a little bit to the stability at speed, it is still doing something either neutral or a bit good. If you change the diffuser there will be one of the same three possible things happening. If you add a bit more width and uptilt to the spoiler, the same three things are on the table.
Does anyone have experience with the carbon fiber one on ebay? Primarily for looks.
do you actually know anything about this issue ......................exactly no , as usual . directed to Bum Bee !Just buy a regular spoiler painted.![]()
I don’t see your point to the replyNo i dont bud. Instead of people worring about that its way better painted. yes or no?
he has no point .......he never does ................he posts complete blather and nonsense and wastes everyones time here ..................maybe a referendum is required ?I don’t see your point to the reply
