Gear logging isn't active yet, but we have MPH on there. Boost by gear right now is programmed as boost by speed.
For logs you can export to CSV or export to JPG.
Awesome thanks. Last question... I sent you a DM yesterday. I cant register to the N54Tech Forum. I dont know who the best BMW Tuner isI email the CSV to myself and then open on the windows interface to look at it in detail and export to photo, if I want to post it. You can probably export the graph off the app too via a screen shot. Direct any questions on the app itself to Donnie here: JB4 Mobile for Apple and Android Smart Phone Support - N54Tech.com - Your Source for International Turbo BMW Racing Discussion
On the MPH depending on the version of the app and what platform it's on, you may need an update to get MPH working properly. Donnie can help with that as well.
HAHAH AWESOME THANKS!All of my PM type systems are disabled. The answer is Terry![]()
so densos gapped to 24 and 93 octane?Yea I agree. After you run map 2 you'll never touch map 1 again. Especially if you have the latest firmware update which should be 5 psi instead of 4 for map 2.
And for what its worth the only requirement to run map 2 is the gapped plugs and premium fuel. Stop wasting your time and go ahead and strap in and enjoy the extra 35 hp from map 2!
Yup thats what im runningI gapped the Densos to 0.022"
With the app you go to settings and then user adjustment and put those numbers in there and Terry says it works on all maps even though it says map6![]()
Where do I enter these settings? Is this for a specific map?
Yea so both fuel and duty bias is for all maps correct?There is no map number above the fuel bias settings.![]()
Possibly but if Terry Shop Stinger is running great at .022 why mess with it?I am going to be installing HKS m40il this weekend. Is the plug gap of .028 good for map 1-2?
