Another interesting thing to consider is wheel nut torque. With all of the talk about pads and rotors, over torqued or unevenly torqued wheel nuts can cause "elastic" rotor distortion as well. (BTW, "elastic" simply means that it isn't permanent and can be undone by loosening the wheel nuts.) When your wheels are removed from the car and put back on, make sure that the technician knows the proper torque spec for the wheel nuts and is using a torque wrench (torque stick for some) and proper tightening pattern to tighten them.
I would encourage those having issues to check this because this is quickly and easily remedied. Keep in mind that no weight/load should be on the wheels and tires when checking the torque of the wheel nuts. The tires/wheels should be off of the ground. This is best done on a lift, but can be done by jacking each tire up individually, loosening all of the wheel nuts (5), and re-tightening them using the proper pattern and torque.
