Brian Keenan
Founding Member
Hey hive. Has anyone put thought into bigger turbos? What might our options be? I'd like to gather some information and figure which brands and models would be best and also review those options.
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
There's a thread on the forum where a shop has already pulled the engine and was nice enough to take up close pictures of the name plate on the turbos - I'll post later with the details when I dig it up
I tried looking up on the manufacturer's website without luck. Perhaps they are too new? Or I wasn't using the right syntax entering the #s
Ah, those turbo blades look a bit bad!
Correct, the bigger the more lag, however if you stick with twin scroll turbos, it will help with lag. As long as you aren’t trying to go single T88 twin scroll you’ll be fine and probably upto 50mm will have minor lag. Of course, if you’re going anywhere near 50mm or higher, that motor needs to be beefed up.I thought bigger turbos took more time to spool up that’s why the response on current ones is so good with minimal lag. Correct me if I’m wrong.
In English please lol you lost me at pulse physics!OEM turbos are not twin scroll. Due to the integration of the exhaust manifold into the head, and the fact there are 3 cyl aside, you can't use equal length pulse physics required by twin scroll design. These turbos are OEM Garret GT 1752 or there abouts. Stock frame Hybrid turbos are an option, but real fun will be had with new bridge pipe from head to v band or standard exhaust flange turbos. Lots of fun times to come with this platform
This is not impossible. The guy was already at 460whp through other upgrades before touching at the turbos.That turbo is not is not a stock frame design, meaning full custom setup needing new exhaust and intake eesign, and is not using electronic wastegate like OEM, so boost control must be done via traditional vacuum source, but not sure the OEM ecu could control that. If that's the what they are using, they went about it the hard way.
I was saying "not impossible", meaning "maybe, i am not sure". It sure looks to me as a hard way of tuning the car too.Not saying impossible, I'm saying much more difficult way to go about it.
