Aftermarket Wheels
What is Your favorite Wheel?
  • Total voters
    235
Not sure if this is the right thread to ask, but I was hoping to use my 2012 Optima's Enkei 18" EDR9's for Winter tires on my RWD Stigner GT at the end of this year. The bolt pattern for them said 5x100/114.3. I one site said the bolt pattern for the Stinger was 5/114.3. Is that just a shorthand way of writing the same thing, or does the "x100" make them incompatible. Here's a photo for reference:
Edit: Okay I'm starting to think the 5x100/114.3 just means 100 OR 114.3, so since the Optima has 5x114.3 I think I've answered my own question.
I would guess it is OR. Your wheels probably have two sets of holes for studs.
You will still want to investigate offset and hub size. The wheel hub on Stinger may be different than Optima. You might be able to order different hub centric rings. I think some 18" wheels have trouble clearing the front Brembos, also.
You're completely right, it never even occurred to me the holes in between the ones I'm using were a slightly different size for a different wheel hub. So I guess it's actually 100 AND 114.3
Hi, these are soooo awesome!
I wonder if Arkperfomance also offer shipping to Germany?
first of welcome to the Forum!!
At the Moment they are my favorits too
@TEAM ARK is it possible for you guys, to ship to Germany?
  • Like
Reactions: Den
Thanks!
I've read some infos on their homepage, for shipping outside US/Canada they would make you a personal offer. But I think shipping costs & german import tax together would be huge... Too bad they don't have a partner shop/reseller in Germany.
19" BBS CI-R from Tirerack. I'm keeping the OEM 18inch wheels for winter. Not as daring as some of the nice 20" wheels posted here, but I'm being a bit chicken. I've never done aftermarket wheels before.
Did u do staggered or all the same size? Those wheels are expensive!!!
Can 19x8.5 fit on the front with no modifications?????
It fits but it does stretch the tyre.
I meant after these tires wear out I’ll get all 4 the same.
All 225?
Aren't you worried that it will alter the car's behavior in the corners? (just asking)
