Soca Boy
1000 Posts Club!
Don’t know if this has been posted, I find when reversing the music will automatically lower.
Mine does that too..now if it only did that when you are looking for an address...lol
Lol, yeah the good old lower the music when your lost.
You see better when the volume is lower!
Just as an FYI the lowering of volume in reverse is a setting you can change.
If you read the manuals we will have to kick you out of the man club....real men don't read manuals!I have to sit down and read my manuals, so much to learn. Which is why this thread is very useful.
Or ask for directions.If you read the manuals we will have to kick you out of the man club....real men don't read manuals!
I didn't watch the video, but in general a catalytic converter is downstream of the exhaust and has nothing directly to do with the turbocharger system upstream. Catalytic converters these days are very free-flowing.
The 3.3TT uses two twin spool turbochargers. A better term would be (in my opinion) a dual step turbo. Each bank is separate and has 3 cylinders. Looking at only one bank:
The turbine wheel on the exhaust side has a graduated surface, one a smaller diameter than the other. Exhaust from one cylinder is sent to the smaller diameter surface of the turbo wheel. Exhaust from another exhaust is sent to the larger diameter surface of the turbo wheel. (The remaining exhaust is simply sent out the tailpipe.) By having two diameters, the turbine can react quickly on quick acceleration (large diameter) and with more force once the turbine spins up (small diameter).
They don’t eat quiche either!Or ask for directions.
Ummmm... And how are you able to slide up the mechanism in the fixed plastic?... Two different face plates or?... Hmmm...Just found out that you can adjust the height of the seatbelt.
Spring loaded , you press top and bottom two pieces together then slide.Ummmm... And how are you able to slide up the mechanism in the fixed plastic?... Two different face plates or?... Hmmm...
I'll need to go check it out. Thanks.Spring loaded , you press top and bottom two pieces together then slide.
Amazed your husband let you out of the kitchen after making the quiche let alone borrow his StingerReal women eat quiche while driving thier Stinger in Sports mode.![]()
Amazed your husband let you out of the kitchen after making the quiche let alone borrow his Stinger![]()
LolIf you read the manuals we will have to kick you out of the man club....real men don't read manuals!
Has anyone discovered how to stop the radio from playing when you turn the car off? Without having to open the doors.
So I just can't help it this response.. and no I'm not a prick.. but have you tried hitting the off button? LOL
Sorry, just couldn't help myself..![]()
Does any car not do this now? Every new or newish car I drive and have been in leaves the audio on until the door is opened or after a lengthy time-out of several minutes.
